which of the 460 heads are better then others?
which of the 460 heads are better then others? Empty which of the 460 heads are better then others?
Post  smoken460ce May 20th 2010, 11:27 pm
I was just wondering what are the better cast iron 460 heads are like what would the C9VE heads be related to far as the other 460 heads go
smoken460ce
smoken460ce
which of the 460 heads are better then others? Empty Re: which of the 460 heads are better then others?
Post  cool40 May 20th 2010, 11:33 pm
same as most cast heads.pi's and cj's are better than the rest of the cast heads,i think.somebody will tell me if i'm wrong. Laughing
Post  schmitty May 20th 2010, 11:52 pm
cool40 wrote:same as most cast heads.pi's and cj's are better than the rest of the cast heads,i think.somebody will tell me if i'm wrong. Laughing
Spot on correct. The D3, DO, C9, C8 are all basically the same as far as performance capability. These heads properly set up will top out around 700+hp. The D2OE(Police Interceptor) and DOOE-R(Cobra Jet)are the better heads, in that order. The DOOE-R heads will do over 800hp properly set up. Cool
Post  smoken460ce May 20th 2010, 11:54 pm
far as the c9's go I know they take the bigger plug I'm guessing the doves and that do to?
smoken460ce
smoken460ce
Post  cool40 May 20th 2010, 11:58 pm
smoken460ce wrote:far as the c9's go I know they take the bigger plug I'm guessing the doves and that do to?
yep Smile
Post  Diggindeeper May 21st 2010, 12:00 am
"best" is purely based on your application.
as far as power making ability....
1 .......CJ (D0OE)
2A .....PI(D2OE)
2B..... Early Castings, C8,C9,D0VE
3....... D3VE,E6TE,E8TE
4....... F3TE, E7TE
5....... D2VE
I dont know if PI's actually would make more power than early heads because of the chamber size issue.
(assuming both are max effort)
ALL are capable heads in the right environment.
Diggindeeper
Diggindeeper
Post  cool40 May 21st 2010, 12:01 am
the c9's are a good head,they'll make a buncha power if done right.they could be a better choice than some,depends on what your doen.i see a 4x4 in your sig so .....just sayen. Smile
Post  smoken460ce May 21st 2010, 12:06 am
cool40 wrote:the c9's are a good head,they'll make a buncha power if done right.they could be a better choice than some,depends on what your doen.i see a 4x4 in your sig so .....just sayen. Smile
Yeah I'm up against on what I want to do I hear so many different things between the dove heads and the c9 heads I'm not really gonna be doin to much to the 460 that I have and I'm puttin a 520 flat top lifter cam so its not like I'm gonna be really goin all out with it considering what the prices are for big block stuff.
smoken460ce
smoken460ce
Post  cool40 May 21st 2010, 12:29 am
the c9 heads are the same as dove's as far as i know.if your gona be pritty mild on the build you'll be happy with the c9's.have fun with it.
Post  the Coug May 21st 2010, 12:31 am
they all work Blake ran a set of D2VE on his 514 and ran some 6.30 1/8 miles thats a 9.80 1/4...
not to shabby for a junk head....
if you are going to run them take them to a machine shop and buy NEW 1 Piece Stainless Steal Valves..... you will be happy you did......
Post  schmitty May 21st 2010, 12:31 am
If you are going to do this for a daily driver or cruizer deal, the passenger car heads are the way to go, Leave the PI's and CJ's for racing. The C9's and DO's are the same head so don't sweat that. If you are looking at more of a pump gas engine, a good set of D3's with their larger combustion chambers make piston selection a little easier. Stay around 9:1 C/R for easy tune and pump gas reliability. Cool
Post  cool40 May 21st 2010, 12:36 am
schmitty wrote:If you are going to do this for a daily driver or cruizer deal, the passenger car heads are the way to go, Leave the PI's and CJ's for racing. The C9's and DO's are the same head so don't sweat that. If you are looking at more of a pump gas engine, a good set of D3's with their larger combustion chambers make piston selection a little easier. Stay around 9:1 C/R for easy tune and pump gas reliability. Cool
x3,the pump gas realy matters if it's gona get driven much.
