AOD behind a BBF
whitefield
8liter
somethingclever
AOD behind a BBF Empty AOD behind a BBF
Post  windsor August 21st 2009, 3:32 am
I copied this from another site...I hope the author doesn't mind! It could probably use some updating as there are a few companies out there now building some stout AOD and 4R70/AOD-E trannies.
I've been using a Lentech Strip Terminator AOD transmission in my '78 Bronco, successfully for years. No electronics, just a throttle valve cable! (The AODE can't be built as strong.) I LOVE IT! Truly a world class piece of workmanship. I will never use any other transmission. Mine is the Stage 1 Strip Terminator AOD capable of 1000 horsepower. They make a Stage 2 AOD capable of 1500 horsepower. I first had an Art Carr AOD built for this application, but I blew it up in less than a year. Then I got serious and had Dynamic Racing Transmissions http://www.dynamicracingtrans.com/ (North Branford,CT) build the Lentech Strip Terminator AOD. (Not affiliated with Lentech Automatics in Canada, but they often work together.) No comparison...I've beat the heck out of this tranny and never had a problem.
This transmission was behind my mild (high torque truck) 466" for years and it's now behind a fresh, potent 508" engine. The low first gear of the wide ratio planetary gearset (2.84:1) and the pushbutton overdrive (.70:1) really give you the best of both worlds (if it's a street vehicle). (I don't like the E4OD...too heavy, too long, too much drag, requires expensive conversion electronics and can't be built as strong.)
Here's some quick specs:
Lentech Stage 1 Strip Terminator AOD, fully automatic (gearshift selectable 1st, 2nd and 3rd with pushbutton overdrive), JW SFI Ultra-Bell, Dynamic Racing Trans TCT 10" 2600 rpm stall (non-lock up) torque convertor, Vasco hardened one piece input shaft, FRPP wide ratio planetary gearset (2.84 1st 1.55 2nd 1:1 3rd .70 overdrive), Lokar stainless steel braided throttle valve cable kit, Lokar stainless steel braided flexible dipstick, finned aluminum deep oil pan (2 quart extra capacity), very large (48 pass) Tru-Cool transmission fluid cooler with Aeroquip -6 AN fittings & stainless steel flex hose, CSR Torque Master flexplate, transmission can withstand 1000 horsepower.
Here are two links:
http://www.lentechautomatics.com/aodproducts.html
http://www.lentechautomatics.com/striptrans.html
I highly recommend using the JW Ultra-Bell (adapter bellhousing). If you decide against their adapter bell housing, then the Lentech adapter plate is the next best method of adaptation. It is 5/8" thick and won't flex. I feel it is the best AOD to 460 adapter plate on the market; besides the JW Ultra-Bell. (Don't ask me how I know...I first made the mistake of buying the Art Carr 3/8" thick adapter plate.)
If you want the installation details, you can read my Complete Overdrive Conversion Article here:
http://www.ford-trucks.com/article/idx/9/063/article/Complete_Overdrive_Conversion_for_7879_Ford_Bronco.html
The JW Ultra-Bell (adapter bellhousing) #92454-AOD is the best way to bolt the AOD to a 400/460 engine (it's installed by cutting the small block bellhousing off the transmission case and bolting the adapter bellhousing to the front pump). Using the JW Ultra-Bell will also require the use of a custom 10" torque converter. If this is too expensive, then the Lentech 5/8" thick adapter plate (as opposed to Art Carr's & others 3/8" thick adapter plate) is the next best method.
I further strengthened my Art Carr adapter plate by fabricating a threaded stud (7/16" fine threads on transmission side - 7/16" course threads on engine side) and elongating the driver side lowest bellhousing bolt hole outward. This enables the engine block, adapter plate and the transmission to be bolted (stud & nut) together. This is necessary when using the AOD-to-460 adapter plate to prevent cracking the flexplate due to the transmission flexing/hinging away from the engine (on the adapter plate bolts) due to the lack of rigidity on the driver side lower mounting. Without my modification, there isn't any mounting support on the driver lower side of the bellhousing; because this area of the adapter plate doesn't bolt to the transmission. If this confuses you, please feel free to email me for further details.
The upgrade/purchase of a Lentech Strip Terminator is absolutely necessary. Please don't make the same mistake I made originally. The Lentech secret is in their 'reverse-third technology' valvebody (it's the solution to even the 'performance AOD's' weak link). I also always use synthetic transmission fluid in my transmissions.
AOD behind a BBF Empty Re: AOD behind a BBF
Post  somethingclever August 22nd 2009, 4:29 am
I think that's from Danny Cabral from back on the network 54 forum......good guy and always posted thorough info...haven't seen him around much on the new board though.
I remember he was always real good with the search function too! Cool
somethingclever
Post  windsor September 5th 2009, 3:27 pm
JW Ultra Bell for BBF on my AOD
AOD behind a BBF Img_0310
AOD behind a BBF Jw_bel10
Post  IDT-572 September 7th 2009, 12:41 am
Windsor, who built your aod ?
Post  windsor September 7th 2009, 10:55 am
Well, I bought it used from a guy that had it behind a twin turbo small block running 9.20's @ 150's mph - made 905 RWHP & 801 RWTQ. He had it freshened with a bunch of new parts from a Ford tranny tech when I bought it, and he then installed the JW BBF bell.
Has a Lentech Strip Terminator Full Manual Trans Brake VB and most of the other doo-dads that you're supposed to do to these things to make them live. But we'll see I suppose.... I think it will be fine for my expected purposes - mid 10's n/a and lots of street time.
HTH - John
Post  IDT-572 September 7th 2009, 1:16 pm
I would like to have one for my 68 f150 short bed , but I can't stand the price of a lentech. Shocked
Post  windsor September 7th 2009, 1:42 pm
Good tech links I acquired doing research on AOD's in no particular order:
http://transmissionadapters.com/Ford%20429-460.htm
http://www.transmissionadapters.com/ford_429%20install.htm
http://www.dynamicracingtrans.com/fordtranny.htm
http://www.atfbilletparts.com/aod-aode-4r70w-transmission-aod-aode-4r70w-transmissions-c-103_56
http://www.artcarr.com/merchandise/details/35/627.acpp
http://www.performanceautomatic.com/ssaodpackage02.htm
http://www.thatmetalbox.com/automotive/AOD/
http://www.broaderperformance.com/Index.htm
http://www.clickclickracing.com/forums/showthread.php?t=7082
http://www.silverfoxtrans.com/silverfoxtrans.com/Home.html
http://www.clickclickracing.com/tech%20mods1.pdf
https://s93.photobucket.com/albums/l47/silverfoxbody/SILVERFOX%20TRANSMISSION/EPOXY%20MOD/
http://www.dirtydogperformance.com/
http://performabuilt.com/FordCars2008.html
http://www.fbperformance.com/fordtrans.asp
Post  8liter September 7th 2009, 3:06 pm
The input shaft looks stout on that AOD, looks kinda like a C6 input. Does it still have the OD?
8liter
8liter
Post  IDT-572 September 7th 2009, 4:21 pm
Thanks for the info............
Post  windsor September 7th 2009, 5:36 pm
8liter wrote:The input shaft looks stout on that AOD, looks kinda like a C6 input. Does it still have the OD?
Yep, still has OD. It's a one-piece 300M shaft.
Post  whitefield September 8th 2009, 11:30 am
Blake , buy the bellhousing and valve body. I have the trans and we can build on and see what happens. we can do it cheaper than what their cost is. bounce
whitefield
whitefield
Post  windsor September 8th 2009, 4:01 pm
whitefield wrote:Blake , buy the bellhousing and valve body. I have the trans and we can build on and see what happens. we can do it cheaper than what their cost is. bounce
I like ^ that ^ idea ^ Very Happy
This link has some good tech mods for the AOD. http://www.clickclickracing.com/tech%20mods1.pdf
Post  IDT-572 September 8th 2009, 5:04 pm
I'm almost positive that's what is going to happen. Cool
Post  windsor September 11th 2009, 2:31 pm
You can find the VB's a lot cheaper, too:
http://www.nmradigital.com/forums/showthread.php?t=89354
Post  88tbird September 13th 2009, 6:57 pm
Wow. I am so interested in this now. I was looking for an E4OD for my 460 swap........ I am now interested in the AOD swap. How does the TV cable hook up to the TB on a 460 EFI? Do I need a special cable?
88tbird
88tbird
Post  Greg_P September 13th 2009, 7:01 pm
Doesn't the one piece input shaft do away with the lockup function on an AOD?
Greg
Greg_P
Greg_P
Post  longroofracer September 14th 2009, 12:23 am
windsor wrote:I copied this from another site...I hope the author doesn't mind! It could probably use some updating as there are a few companies out there now building some stout AOD and 4R70/AOD-E trannies.
Here are two links:
Yes, That was Danny Cabral ... here is the link in case anyone wants it...
http://www.460ford.com/forum/showthread.php?t=96936
longroofracer
longroofracer
Post  windsor September 14th 2009, 4:21 am
Yeah...I didn't want to use his name without his permission...as dumb as that may sound.
Greg, yes, the one peice input shaft does eliminate lock up function I believe.
Post  windsor September 14th 2009, 4:27 am
88tbird wrote:Wow. I am so interested in this now. I was looking for an E4OD for my 460 swap........ I am now interested in the AOD swap. How does the TV cable hook up to the TB on a 460 EFI? Do I need a special cable?
What kind of efi/throttle body you using?
Most people use the Lokar cables for the Throttle Valve installation http://www.lokar.com/product-descriptions/stainless-hitech-kd-kits.htm I think you could make it work on just about any application, but it may take a bit of jerry rigging.
It's a manual adjustment...AOD's don't use electronics for shifts. I'm using a manual valve body so no cables get hooked up anywhere, except for the shifter.
Try a google search on Lokar AOD or something like that and a lot of pages come up you can get ideas from. Hope that helps.
Post  88tbird September 17th 2009, 12:10 am
I was going to stay with the truck EFI and TB set up. I thought you had to have the TV cable hooked up if you run the AOD?
I will check out Lokar.
88tbird
88tbird
Post  windsor September 17th 2009, 3:41 am
If you use a full manual valve body you don't need the TV cable. But, if you want to keep automatic shifting ability, you will need a TV cable. The Lokar one is supposed to be good.
Post  88tbird September 17th 2009, 8:44 pm
Awesome. Thanks. So tell me about the drivabillity of the AOD behind the 460.
88tbird
88tbird
Post  windsor September 18th 2009, 4:29 am
I'll tell you in a few years when I get the car running.........
Crying or Very sad No Sad
Post  88tbird September 18th 2009, 9:39 pm
Damn. I was hoping a little sooner.
88tbird
88tbird
Post  jasonf September 18th 2009, 11:24 pm
windsor wrote:I'll tell you in a few years when I get the car running.........
Man you are living my life. Maybe it is a Falcon thing. lol!
