Stock short block and cam
Stock short block and cam Empty Stock short block and cam
Post  fastford May 31st 2010, 5:20 pm
What is the most lift you can run on a stock piston with a 2.20 valve?
fastford
fastford
Stock short block and cam Empty Re: Stock short block and cam
Post  schmitty May 31st 2010, 11:15 pm
Need more info than that probably. What is the duration you are looking at (duration and lift come together to determine how much lift before hitting the pistons), and how much lift are the heads capable of. If they are stock pistons, you won't want to rev that thing too high, as cast pistons don't like a lot of speed, and the heads if stock can only do about .550 or a litle more depending on how the guides are set up. Cool
Post  fastford June 1st 2010, 12:58 pm
241-249@.50 582-600 ported D3 with a 2.20 1.76 valves
fastford
fastford
