DOVE A block
8liter
DOVE A block
Looking for a good DOVE block as close to wky as possible.
Casey
Casey
8liter- Posts : 202
Re: DOVE A block
im not close, joliet area, 400.00
BOSS 429- Posts : 2372
Re: DOVE A block
Got one in Dayton, tn $400 will need bored, can drop off in owenboro.
Re: DOVE A block
If this was for a small stroker build ? wouldnt the D9 block be a better choice, because of the slightly longer cylinders ?
RapidRuss- Posts : 334
Re: DOVE A block
even tho the cly are longer,they are not as strong as a dove
Re: DOVE A block
BOSS 429 wrote:even tho the cly are longer,they are not as strong as a dove
Well ya learn something everyday ! Never knew that obviously... I had thought from the great Block Summit that all the blocks were pretty much equal....
Re: DOVE A block
RapidRuss wrote:BOSS 429 wrote:even tho the cly are longer,they are not as strong as a dove
they are all about the same just the D9TE have longer cyl blore
the Coug- Posts : 3055
Re: DOVE A block
not the same at all, main web is stronger,all the way to the thicker pan rail, TAKE A LOOK AT ONE
theres really to different dove blocks, in fact one has thicker walls,and we have went 4.500
with a lot of them
K
with a lot of them
K
Re: DOVE A block
and just how many have you ever broken, from the hp being to much..........Zero Truth of the matter is that a 2 bolt Block, D0VE or D9TE same hp rating between 750 and 800 and then you have to get either 4 bolt mains or aftermarket block....or have the Main caps Strapped......cuz no Girdle will fix cap Fretting...(walking)
Re: DOVE A block
lol, what ? anyone can see a dove is stronger,and better made, i wouldnt bother to use a D9 for over 750, im not sayin there bad,just that a DOVE is better, ray charles can see that
Re: DOVE A block
Georgia..... Georgia..... Your on my mind.....
IMO with 4 bolt caps yes the dove is better, with 2 bolt caps they might as well be the same block. I've seen a couple d9's thick enough for 4.500 to and seen some doves on the thin side, so it's a crap shoot as far a cylinder bores......
Re: DOVE A block
dfree383 wrote:Got one in Dayton, tn $400 will need bored, can drop off in owenboro.
What is the bore right now? Has it been decked or align honed yet?
Thanks.
8liter- Posts : 202
Re: DOVE A block
Factory bore, no machine work, one hole had some rust and may not clean up at .030
Re: DOVE A block
Do you come thru Clarksville on the way to owensboro?
Thanks.
8liter- Posts : 202
Re: DOVE A block
Come close could meet you in BG or Nashville on 65?
Re: DOVE A block
Do you want this block or not? Probably heading to Owensboro next weekend.
Find one?
Just curious if you found a block yet? Let me know if not.
ur2slow- Posts : 2
Re: DOVE A block
Yes...thanks. I got one at NMRA in BG.
8liter- Posts : 202
» DOVE block
» WTB DOVE-A BLOCK
» WTB: Dove-A block or A-460
» wtd: a460 block or a dove 460
» Dove block
» WTB DOVE-A BLOCK
» Dove block
