dominator carb?
dominator carb?
where is the list number at? i have an older 1150 dominator that i want to convert to e85 but cant find the list#. i need it to order my conversion kit thanks
new2460- Posts : 195
Re: dominator carb?
new2460 wrote:where is the list number at? i have an older 1150 dominator that i want to convert to e85 but cant find the list#. i need it to order my conversion kit thanks
If your going to buy the QF dommy kit, its a 3 circut kit. Thats prolly the only info you'll need. Does your dommy have 3 airbleeds per venturi? Its a 3 circut then. If it has 2 its a two circut. I used the 4150 e85 kit they sold on my 3 circut and it works fine. I would like to get that 3 circut kit to see if it makes much of a difference.
8liter- Posts : 202
Re: dominator carb?
carbs are not my thing how can i tell if i have a 2 or 3 circut? can you show me a pic? thanks
numbers i found
the only numbers i found on it are 12r-9027b also L-7320 then underneath 3012. i know its an 1150 dominator. thanks jim
Re: dominator carb?
Looking down the bore throughts you'll see either 2 or 3 little "jets" near where the booster is attached to the carb body. Annular boosters and/or 3 circuit air bleeds are a great start for any carb.
torkair- Posts : 404
Re: dominator carb?
L-7320 IS the list number and part number of that carb. It's originally a two circuit 1150 unless someone has modified it.
