offset ford 9 inch hogshead ?
mach1charlie
offset ford 9 inch hogshead ? Empty offset ford 9 inch hogshead ?
Post  mach1charlie August 21st 2009, 7:30 pm
what is the offset so I can center the pinion ? This is for a trike project. Whats the narrowest 9 inch you have ever seen?
TIA Charlie
mach1charlie
offset ford 9 inch hogshead ? Empty Re: offset ford 9 inch hogshead ?
Post  jasonf August 21st 2009, 7:38 pm
If you get an early style housing the center section of the housing is the smallest. Currie also makes a new one like it for street rods. These would be the best for what you want to do. Rear ends in a dragster are just barely wider than the housing itself so that would be your limiting factor.
Post  Northwest outlaw August 21st 2009, 7:55 pm
If you want to go small look for a small web housing.
Northwest outlaw
Northwest outlaw
Post  Northwest outlaw August 21st 2009, 8:00 pm
here is a small web
offset ford 9 inch hogshead ? 045-1
Northwest outlaw
Northwest outlaw
offset ford 9 inch hogshead ? Empty Rear
Post  mach1charlie August 21st 2009, 8:14 pm
This will be a "hardtail" 2x3 welded to housing. frame rails about 24 inches apart or less. Narrowest I can go would be 1 side 1inch away from center section and other side 1 inch plus offset.
Charlie
mach1charlie
Post  mach1charlie August 21st 2009, 8:16 pm
Yup, looks like the one I have to cut, ford truck.
mach1charlie
Post  res0rli9 August 22nd 2009, 8:29 am
the off set on my pinion was 1 3/4"
Post  BOSS 429 August 23rd 2009, 11:19 am
mach1charlie wrote:what is the offset so I can center the pinion ? This is for a trike project. Whats the narrowest 9 inch you have ever seen?
TIA Charlie
ues a 8'' rear, more ground clearance for ya,smaller ,lighter, u could narrow a 8 to 24'' w/drum brakes,maybe a little wider,but could be made very narrow non the less
Post  bosshoss August 23rd 2009, 1:03 pm
What are you using for a reference point?
When I jig mine I measure everything from the pinion centerline out.
Pretty tough to tell otherwise most stock deals are offet to the pass side from the factory. Its easy to get confused if you are trying to work backwards from the bearing ends or spring perches.
I use a stripped old stock center section that I have laying around.
dkp
bosshoss
bosshoss
