35 spline upgrade question
+6
bosshoss
64 fairlane
Race Ready Fabrications
duff429
10 posters
35 spline upgrade question Empty 35 spline upgrade question
Post  duff429 June 11th 2010, 3:09 am
ok after alot of thought im thinking of just upgrading to a 35 spline set up in my 1970 cyclone. my friend said that 35 spline axles with mosers sealed bearings mite not fit in my stock 9 inch housing because they are bigger diameter then 31 ,and if im spending the money on all new i should just get a complete rear end.my car is a factory 31 spline so i dont see how going to 35 spline would not fit???
i think it will fit but after he said that i just want to make sure. thanks
duff429
duff429
35 spline upgrade question Empty Re: 35 spline upgrade question
Post  Race Ready Fabrications June 11th 2010, 5:47 am
35 spline will require the use of a 3.250 case. Your case is probably 3.062.
Post  duff429 June 11th 2010, 6:09 am
ok thanks... im going to sell the one thats in it now and proply just get a whole new 3rd member from moser. looking at jegs to piece together what i want its almost the price as one from moser.. but i didnt shop around to much yet.
duff429
duff429
Post  64 fairlane June 11th 2010, 7:42 pm
You can get a spool for 35 spline axle and use the 3.06 rear end. I don't now if you can get a open diff or posi though. You might want to check into this. Hope this helps. Aaron
64 fairlane
64 fairlane
Post  bosshoss June 11th 2010, 8:35 pm
As far as the axles fitting the housings goes. If you remove the original oil seal you should be fine with the 35 splines in the stock housing.
dkp
bosshoss
bosshoss
Post  cool40 June 11th 2010, 9:18 pm
35's will fit the stock housing,the housing being the part the axle & bearing slide into.the 3'rd member,chunck,pumpkin,whatever should be upgraded to a 3.250 case or your pissen in the wind.i dont know if you can get a smaller bore/spline spool that'll work with 35's but the stock case is the weak link. Smile
Post  DILLIGASDAVE June 12th 2010, 2:02 am
If your talking about the factory 9" housing ends, both of the big Ford housing end styles (for the big 3.150" OD axle bearing) should work with a Moser 35 spline axle & a standard single row sealed bearing. But these days I'm not sure about the small Ford housing ends & 35 spline axles (for the small 2.835" OD axle bearing). I could swear many years ago Moser made/had a speical axle bearing for using their 35 spline axles with the small housing ends, but that was years ago & I might be mistaken.
Post  TravisRice June 12th 2010, 8:09 am
DILLIGASDAVE wrote:If your talking about the factory 9" housing ends, both of the big Ford housing end styles (for the big 3.150" OD axle bearing) should work with a Moser 35 spline axle & a standard single row sealed bearing. But these days I'm not sure about the small Ford housing ends & 35 spline axles (for the small 2.835" OD axle bearing). I could swear many years ago Moser made/had a speical axle bearing for using their 35 spline axles with the small housing ends, but that was years ago & I might be mistaken.
Yes Dave you are correct, I had a set. I am pretty sure they still offer that package although other companies don't.
Travis
Post  richter69 June 12th 2010, 10:10 am
I have Strange 35 spline axles, they require a 3.250 side bearing in the case but will work with the small Ford bearings on the housing.
Post  cool40 June 12th 2010, 10:36 am
richter69 wrote:I have Strange 35 spline axles, they require a 3.250 side bearing in the case but will work with the small Ford bearings on the housing.
dam,same car same axle's Laughing x2
Post  richter69 June 12th 2010, 10:46 am
your HeRo status just jumped 3 points................. Very Happy
Post  cool40 June 12th 2010, 7:40 pm
when you gona paint your's?woop's,did i loose any points? Laughing
Post  richter69 June 12th 2010, 7:55 pm
it is painted...........
Post  duff429 June 15th 2010, 2:42 am
havent been on here for a few days.. thanks for all the replies. im just gonna get a new case and go all new. it would be a shame to modify a factory SCJ 3rd member. so ill sell it and do the new route.. i was thinkin of a spool cause there are cheap but i want a locker.
duff429
duff429
Post  BOSS 429 June 16th 2010, 1:20 am
duff429 wrote:ok after alot of thought im thinking of just upgrading to a 35 spline set up in my 1970 cyclone. my friend said that 35 spline axles with mosers sealed bearings mite not fit in my stock 9 inch housing because they are bigger diameter then 31 ,and if im spending the money on all new i should just get a complete rear end.my car is a factory 31 spline so i dont see how going to 35 spline would not fit???
use 33 moser we have ran 1000 plus hp with them for years
from 3780 lbs car to 2900 pounds
Post  cool40 June 16th 2010, 10:43 am
x2,dont get more than you need.i know a brand x guy still runnen 31 spline in a 2500# door car goen 5.80's.
Post  duff429 June 16th 2010, 8:40 pm
I was gonna just keep the 31 spline locker that's in it but its a scj rear so I could rebuild it and sell it and I already gotta upgrade to mosers so I was just thinkin goin to 35 spline. My car is a 4 speed and plan on doin a 10.0-11.0 comp. 557 with p51s and my low rise dual quad or victor if I can fit under a stock hood so I think if I can get 1200 for my scj 3rd member and I already sold my stock axels why not just get a 35 set up. Axles from moser will be the same price, a locker will be 585 or so but I'll need to get gears case etc. Or spend 1600 and get one from moser. All set up. Haven't decided if it cheaper to do that or or go get stuff from jegs and forum members
duff429
duff429
Post  bosshoss June 16th 2010, 8:58 pm
I vote for the complete package from moser.
dkp
bosshoss
bosshoss
Post  Nevs June 16th 2010, 9:40 pm
I respectfully disagree. I'd overbuild for future growth, the cost difference will be negligible. The knowledge that you aren't going to break it is priceless.
Post  cool40 June 16th 2010, 11:42 pm
yep,if your gona buy a new chunck anyway i'd go 35's too.it'll all cost bout the same and you wont break it,the 4 speed may be another issue. Smile
