MSD PICK-UP COIL
MSD PICK-UP COIL
Couldnt get the Pinto started Saturday nite outta the trailer. No spark at the coil. Originally thot the coil was bad. Turned out, the MSD pick-up coil was bad. Did ya know, it's the same p/u coil style as a stock Duraspark? If ya grind off the rivets/pins to get it off the back-up plate, it'll bolt right into the MSD dist. You'll needta do a "field splice" on the wiring inside the cap. Sure saved an otherwise bad evening.
JACKAZZFLATZ- Posts : 249
Re: MSD PICK-UP COIL
Thats why alot of folk just run the Duraspark, plus its smaller.
jones- Posts : 2230
Yep,still have a couple spares in the trailer,even though I run a Crank trigger now,someone else WILL need one sometime.
» p51 heads vs tfs heads
» External oil pump -- Converting a conventional wet sump oil pan
» A little pick me up
» Need help with Carb Pick
» new oil pan pick up and pump
