ford 9" 3.73 gears
ford 9" 3.73 gears
Anybody have any 3.73 gears for sale?
tiger- Posts : 272
NOT MINE but found on local site
NOT MINE!! but found on local site if you don't have any luck finding them here. somewhere in IL, he did not leave the town
Ford 9’ Richmond Rearend Gears 390’s ,mint cond.. 8 passes $100.-
Ford 9’ Motive Gear 355’s, mint cond.. 6 passes $100.-
Email me at jhaley566@comcast.net with questions
nada 50- Posts : 32
Re: ford 9" 3.73 gears
Got a set of original Ford 3.70 gears. $100.00 plus shipping from 47452. They should weigh about 22lbs when boxed up.
They are still in the housing so I gotta check them out first. Let me know if ya think you are interested. Pretty frigging hot out to be taking a rear apart!
John.
John.
fordman460- Posts : 100
3.70 gears
I have a set of 3.70 gears in set up on a 28 spline posi unit in a stock pumpkin. will take $300 for the whole deal ready to bolt in.
rear end
I may be wrong but the 3.73 gears are for a 8.8 inch rear - the 3.70 are 9 inch
BTW 3.70 I believe these are Drag Pack gear ratio
And the 28 spline posi in a punkin is a deal - they are hard to come by - most were 31 spline like in the drag packs
Rvesterby- Posts : 130
Rvesterby wrote:I may be wrong but the 3.73 gears are for a 8.8 inch rear - the 3.70 are 9 inch
Yep, 9 inchers are 3.70. Not in a Drag Pack though. Found in trucks mostly if not only. Yep, the 28 spline Traction lock is getting hard to find.
» 4.30 or 4.56 gears(9" ford)
» ford 8.8 4.56 and 4.88 gears
» Ford 9" Pro Gears
» FORD 8.8 WITH 3.90 GEARS
» Wanted Ford 9" aftermarket case for 3.250 bearing and pinion support/3:91 gears
» Ford 9" Pro Gears
