What is this ?
+7
DanH
GaryH
Darrin Gorham
11 posters
Re: What is this ?
Its a rudder for a duck.
Re: What is this ?
new prostock heads?
Darrin Gorham- Posts : 180
Re: What is this ?
im trying to read what letter is in front of the part# looks more like a "c" but only 10 bolt provision unless the shaft mout bases are covering up the other 8 but i thought they were in another location
Re: What is this ?
M-6049-e460? Do any other heads NOT have the center top valve cover bolt hole?
For use with M-6010-A500 Ford Racing cylinder block, other blocks require modification to accept this head
Used for professional competition: NHRA Pro-Stock Class
Made from 356-T6 aluminum, with steel valve guides with a bronze liner, and a premium valve seat insert material compatible with titanium valves
Raised intake and exhaust ports
65cc wedge-style combustion chamber
4.600" recommended bore size minimum
2.450" intake, 1.880" exhaust recommended valve diameters
Shaft-mounted rocker arms and offset roller lifters required
Wedge-style combustion chamber, canted valves and tall, high flow ports
Requires custom made intake
Re: What is this ?
from the pic the valves look like they have no-cant
Re: What is this ?
Jessel did that one . Looks like it'd beat welding stands together .DanH wrote:one bar rocker shaft system. who makes it?
Re: What is this ?
Lem Evans wrote:Jessel did that one . Looks like it'd beat welding stands together .DanH wrote:one bar rocker shaft system. who makes it?
I agree, too bad it's Jesel
Nevs- BBF CONTRIBUTOR
Re: What is this ?
Hillary Clinton without her makeup? No?
OahuEli- Posts : 6
Re: What is this ?
Looks to me like it says M-6049-D460. The SVO Yates Pro Stock head?
jpierce55- Posts : 111
Re: What is this ?
Lem said its C460 , to tell the D head the middle (EX.side) bolt holes are moved in toward the V/C. under V/C are moved down
DanH- Posts : 1081
Re: What is this ?
DanH wrote:Lem said its C460 , to tell the D head the middle (EX.side) bolt holes are moved in toward the V/C. under V/C are moved down
LOL, guess I am blind.
Re: What is this ?
The new heads you are working up for me? Check is in the mail!
514Fox87- Posts : 436
