Ford 9 3/8
Ford 9 3/8 Empty Ford 9 3/8
Post  TorinoGT June 27th 2010, 7:34 pm
Hopin someone here can help me out here...
My father has a 1966 Galaxie 7 Litre (428fe) 4 speed... the rear axle is a ford 9 3/8, open with some ungodly high ratio probably 3.00:1 or worse... there is NO aftermarket for this axle at all.
my question(s) are... is there any gears and or limited slips avail for this? can you install an entire 9 inch 3rd member into the housing and use the currents axle shafts? what can I do to get a better ratio and a limited slip or locker!? help!
Shane
TorinoGT
TorinoGT
Ford 9 3/8 Empty Re: Ford 9 3/8
Post  Mike R June 27th 2010, 8:42 pm
Yes, 9 inch parts will go right in
Post  Paul-uk July 1st 2010, 11:09 am
Came up across the road recently.
http://www.460ford.com/forum/showthread.php?t=146197
Paul-uk
Post  nuclearcobra July 24th 2010, 10:48 am
There is a company that makes parts for that rear also called a 9-1/2 sometimes, i cant remember the place but i'm lookin and i think i have a traction lock unit for it that came out of the 70 lincoln that my 460 came from.
nuclearcobra
nuclearcobra
Post  TorinoGT July 24th 2010, 1:36 pm
nuclearcobra wrote:There is a company that makes parts for that rear also called a 9-1/2 sometimes, i cant remember the place but i'm lookin and i think i have a traction lock unit for it that came out of the 70 lincoln that my 460 came from.
any chance you have a gear like a 3.55 or so too?
TorinoGT
TorinoGT
Post  DILLIGASDAVE July 25th 2010, 7:28 pm
Mark Williams has 9 1/2" stuff, but it's more aimed at ultra high HP drag applications.
