New build hp numbers?
bb429power
70429scj
New build hp numbers? Empty New build hp numbers?
Post  70429scj July 8th 2010, 11:51 pm
.030 460 trw flatops zero deck block scat h beam rods eagle crank 3.85 stoke. tfs street heads. c460 cam 244-254 lift 595-621 victor intake with 1050 quick fuel carb msd ignition the limiting factor on hp is 1 7/8 primary tube to keep the power steering. Just wondering how close to the old crate motor on hp and tq, will it run on pump 93 octane gas? I know the headers can rob 25+HP
Thanks,
Steve
70429scj
70429scj
New build hp numbers? Empty Re: New build hp numbers?
Post  bbf-falcon July 9th 2010, 12:41 am
Is that a flat tappet cam or roller?
Post  res0rli9 July 9th 2010, 12:46 am
looks like the same cam that Lem sells that came in some of the 460 create motors
Post  the Coug July 9th 2010, 6:08 am
Don't buy an Eagle Crank in stock stroke....... the Factory is much better crank and will handle a Butt load of power.....
Post  bb429power July 9th 2010, 7:33 am
the Coug wrote:Don't buy an Eagle Crank in stock stroke....... the Factory is much better crank and will handle a Butt load of power.....
Listen to the guy, he helped with with the same problem. I was gonna use an eagle! silent
bb429power
bb429power
Post  dfree383 July 9th 2010, 10:08 am
if you havent purchased the parts, get a SCAT stroker kit from Adney at Performance Crankshaft. Much more bang for the $$$. 4.300 stroke is nice and it will boost your torque a whole bunch.
The Flat tops with the heads and cam you are looking at will make more compression than is safe on 93 pumps gas (you'll be in the 12:1 range). I'd suggest the stroker kit with a dished piston and keep it in the 10-10.5 range for a street performance driver.
at 521" with the out of the box TFS Streets 600-650hp should be pretty easy. You'll be pretty similar to the Ford Crate Motors.
Post  IDT-572 July 9th 2010, 3:38 pm
I will add to what Randy said................ (Don't buy any stroke cast Eagle crank) If you are going to make any kind of hp.
New build hp numbers? Empty Parts
Post  70429scj July 9th 2010, 5:32 pm
Cam is a hyd crate motor from Lem. I already had all the parts bought,balanced and built I think before Blake had problems with the eagle crank in his motor. Motor has a Scotty J soild lifter cam already, was looking to detune with the hyd cam and be a little more conservite on the crank. Understand on upping the octane.
Thanks,
Steve
70429scj
70429scj
Post  dfree383 July 9th 2010, 9:25 pm
What are the specs on the solid cam?
New build hp numbers? Empty cam
Post  70429scj July 9th 2010, 10:10 pm
int.256--exh.266 int .626--exh.648 lb lift int.362--exh.375 cl line int 104 exh 110.8 lb sep/adv int 107.4--exh 3.4 advance
Steve
70429scj
70429scj
Post  nuclearcobra July 17th 2010, 9:40 am
What part # on the pistons ?
nuclearcobra
nuclearcobra
New build hp numbers? Empty pistons
Post  70429scj July 17th 2010, 7:10 pm
speed pro--trw #2602f.030
Steve
70429scj
70429scj
Post  rmcomprandy July 17th 2010, 9:42 pm
70429scj wrote:int.256--exh.266 int .626--exh.648 lb lift int.362--exh.375 cl line int 104 exh 110.8 lb sep/adv int 107.4--exh 3.4 advance
Steve
That C460 cam will exhibit about the same manners without as much power.
