deck side V intake side
what is the ratio for cutting the intake side of a head to correct for cutting chamber side?
Re: deck side V intake side
Let me go check though just to make sure.
bb429power- Posts : 3129
if you are only going .030 don't worry....
if you go .040 or over you take off half of what you take from the head surface
the Coug- Posts : 3055
My bad, I was thinking for an olds. The book I have says for a 0 degree (big block ford) head the amount removed at the deck X 1.0 = amount to be removed at the intake side.
Then it says the amount removed at the deck X 1.4 = amount to be removed at the bottom of the intake manifold (if necessary).
But listen to Randy, he's more experienced than me.
so if i take .050 off deck side, then .025 off intake side.it also appears at some point i-manifold holes will have to be slotted?i had
forgotten how much went into custom engine assembly.really is rewarding though.
» Modifying an intake, tall deck to short deck
» WTB Yates C3 8.2 Deck Intake Manifold
» Eliminator Big V Intake Vs KFM Custom Trick Flow A460 single Dominator Intake
» In need of FRPP C460 cast intake for 10.3 deck
» need MSD dizzy for 351w/with victor intake 9.5 deck
