D3 compression ratio
342g
bb429power
mitch
D3 compression ratio Empty D3 compression ratio
Post  mitch July 12th 2010, 2:47 pm
I have a set of D3 heads available I could use for a build, is it possible to get the cr up to about 14:1 with them or would I be better off selling them and buying small chamber heads?
mitch
D3 compression ratio Empty Re: D3 compression ratio
Post  dfree383 July 12th 2010, 2:55 pm
What the CID? Flat tops in a 466 usually get about 9.25-9.5:1 with D3's
Post  bb429power July 12th 2010, 3:00 pm
Do you have an idea of what the chamber size is or will be after a valve job?
bb429power
bb429power
Post  342g July 12th 2010, 3:02 pm
I had 13.5-1 with 95 cc heads, and dome pistons.
342g
342g
Post  mitch July 12th 2010, 4:27 pm
ci would be .060 maybe .080 over, stock 460 crank, no idea what the chamber size will be. Just wondering if it is practical to build a high compression engine with the D3 heads.
mitch
Post  dfree383 July 12th 2010, 4:33 pm
You need custom Pistons with D3's to get 14:1, Going to need about a +24-30 cc piston.
Post  mitch July 12th 2010, 8:01 pm
would you guys recommend using custom dome pistons, or sell the D3 heads and buy dove heads?
mitch
Post  Maddmattmustangs July 12th 2010, 8:05 pm
I would think that you would be better off just upgrading to a better head with a smaller chamber. The ford racing SCJ head would be a good head for you to check out. small chambers, good flow, updated valve angles and better chamber design. or you could get the P-51's which are very strong heads. JMO.
Maddmattmustangs
Maddmattmustangs
Post  mitch July 12th 2010, 8:38 pm
Maddmattmustangs wrote:I would think that you would be better off just upgrading to a better head with a smaller chamber. The ford racing SCJ head would be a good head for you to check out. small chambers, good flow, updated valve angles and better chamber design. or you could get the P-51's which are very strong heads. JMO.
I know these are good heads, but this is a budget build for a stock class puller that requires oem iron heads
mitch
Post  schmitty July 12th 2010, 9:22 pm
It's going to be a lot easier to get there with the DOVE's, but it'll still take a set of dome pistons. DOVE heads are still relatively easy to come by and affordable. Cool
Post  Diggindeeper July 12th 2010, 9:53 pm
I dont know what you have done to the heads, or your budget. if the heads are nicely ported, and money is tight, just run em with a 10cc dome. imho
Diggindeeper
Diggindeeper
Post  dfree383 July 13th 2010, 3:16 pm
a 10cc dome isnt going to get 14:1 with a D3 Head.
Post  Diggindeeper July 13th 2010, 4:32 pm
nope but gets him ready for a smaller chamber head in the future.
I dont know the ins and outs of the build but I wouldnt let it make it or break it as far as getting out there. I personally would rather be out there getting last place than watching from the stands. One of my friends ran D3 headed flat top piston 460 for 5 years and seldom if at all seemed to get last place...didnt win either but at least he was out there...fwiw.
Diggindeeper
Diggindeeper
Post  dfree383 July 13th 2010, 4:36 pm
true, but if your buying pistons, get what you need.
Post  jones July 15th 2010, 8:38 am
I'd start atleast with a set of C8's or C9ve.
I owned a set of super nice D3's and after being decked they still CC 94. I believe they are in the 100cc range from the factory. You will just be that much ahead of the curve if you start out with a non emmission cylinder head and smaller chambers.
jones
