detroit locker in heavy 3900 lb. Truck with transbrake.... Will it last?
detroit locker in heavy 3900 lb. Truck with transbrake.... Will it last? Empty detroit locker in heavy 3900 lb. Truck with transbrake.... Will it last?
Post  bluef100fe July 12th 2010, 3:06 pm
anybody running a detroit locker and using a transbrake? Would it be reliable? I'm finding that since i upgraded my racing tires on the truck my traction lock posi isn't staying locked up coming out of the burnout box or at the hit. I would go straight to a full spool but I still street drive this thing and occasionally tow a 7000 lb. trailer with the truck. I want to have my cake and be able to eat it too if possible. What do u guys recommend?
bluef100fe
bluef100fe
detroit locker in heavy 3900 lb. Truck with transbrake.... Will it last? Empty Re: detroit locker in heavy 3900 lb. Truck with transbrake.... Will it last?
Post  dfree383 July 12th 2010, 3:13 pm
Yes it should last.
Post  bluef100fe July 13th 2010, 1:44 pm
So I'm looking detroit lockers and seems theres three different styles nowadays the original cam lock style which i'm told breaks axles in drag racing applications, the newest is a gear locker which is suppost to be the best for what i'm trying to do and then the true trac which is somewhere in the middle? Has anybody used all three or any of these? How did they hold? Can u feel them unlock and lock on the street or track? I could feel the cam locker style on the street and i did care for it all every time you let off the gas when cruising the thing would unlock and the car felt like it was in neutral until you stepped on the gas, then it felt like it slammed back into like dumping a clutch at speed. Just harsh and jaring the driveline..... I can see why they break axles. Anyway, im leaning towards the gear locker unless you guys convince me otherise?? thanks for reading my rambling.... Also wondering if i should update my axles to 35 spline from the 31 spline i have now?
bluef100fe
bluef100fe
Post  dfree383 July 13th 2010, 2:22 pm
The Axle upgrade never hurts, especialy if your have alot of time on them
I've used the old style Detroit Lockers in the past and never had an issue, they are noisy but work well. I've also never heard they like to break Axles.
I just put together a Thorensen T-2 8.8 for my Dads 91 LX, not sure when we'll get to run it, but it sure looks nice, it has spiral looking gears. May look in to them, I will tell you it wasn't cheap.
Post  bluef100fe July 13th 2010, 3:42 pm
well it looks like the guy i was talking to didnt have everything thing correct the gear locker is actually the true trac. Which is still around 500 dollars from what ive seen and only available in 31 spline to boot. Will have to look into the thorensen unit if its available for a 9 inch. The true trac has the spiral cut gears from what im seeing/reading also. Thanks dave the headache continues.
bluef100fe
bluef100fe
Post  AZFairlane July 13th 2010, 8:46 pm
Here's one for you to check out, expensive but a lifetime warranty.
http://www.wavetrac.net/
AZFairlane
AZFairlane
Post  BigDave65 July 14th 2010, 4:39 pm
Had a buddy running a locker in a 2800 lb 67 Mustang w/ a 557. Car would go 5.40's, ran a locker in it for a little while but it finally giave up and he installed a spool.
BigDave65
BigDave65
Post  bluef100fe July 15th 2010, 8:33 am
Well that doesn't sound so promising. Although a lot lighter car and going a lot faster than my truck thanks
bluef100fe
bluef100fe
Post  dfree383 July 15th 2010, 8:37 am
They did come factory or optional on quite a few fords in the day........ They are the most durable of the streetable differentials offered IMO.
If you think you making more than they will handle a spool is about your only option..... and not the best on the street, although I have use them in limited occasions.
Post  devildog July 15th 2010, 9:43 am
They make a 35 spline detroit locker if you are worried about the others and still use it for the street...then since you would already have the axles you could switch to a spool when you felt like it........D
devildog
Post  bluef100fe July 15th 2010, 3:34 pm
I'm strongly considering the 35 spline deal. Thanks all.
bluef100fe
bluef100fe
