Swap from 4x4 case
Swap from 4x4 case
My project was going and actually did go into an 85 Bronco. I came to my senses and pulled the motor and ditched the Bronco and got the LX. Fast Forward to present, I have a rebuilt C-6 in a 4x4 case. Anyone know if there is a way to convert the tail shaft to work with out the crank case haha. Been on the look out for a case but not really coming up with anything. Everyone is trying to sell a transmission, not just a case.
Thanks,
K.C.
Thanks,
K.C.
Re: Swap from 4x4 case
all you need is the tail shaft and tail housing all other parts should interchange. You can probably get these parts at a wholesale tranny part store such as W.I.T.(whatever it takes) this is one of the stores we have around here.
lghting94- Posts : 762
Lucky I got a friend that has a bbf c6 for $100 + shipping complete it will need building been sitting for a long time or if you only the case and tail shaft can take it apart for shipping wouldn't be as bad on it if you don't find one it is in fitzgerald ga.
Jim
Jim
Where are you located? im sure i have a car extension housing and shaft around here some where.
in4x4guy- Posts : 3
lghting94 wrote:all you need is the tail shaft and tail housing all other parts should interchange. You can probably get these parts at a wholesale tranny part store such as W.I.T.(whatever it takes) this is one of the stores we have around here.
69F100 wrote:Lucky I got a friend that has a bbf c6 for $100 + shipping complete it will need building been sitting for a long time or if you only the case and tail shaft can take it apart for shipping wouldn't be as bad on it if you don't find one it is in fitzgerald ga.
Jim
in4x4guy wrote:Where are you located? im sure i have a car extension housing and shaft around here some where.
schmitty actually did the opposite of what I'm doing and he is sending me the parts. THX guys.
» 2 c6 questions. bell housing ear trim and case swap(sb to bb)
» NEED AFTER MARKET N CASE FOR 9" ASAP
» F apply or FF apply lever?
» Which c6 case should I get
» c-6 4x4 t-case
» c-6 4x4 t-case
