A little Help!
+9
Race Ready Fabrications
13 posters
A little Help! Empty A little Help!
Post  whatbumper July 20th 2010, 11:41 pm
I am building a ride for a guy but we don't know what to use yet. He has a 6 cylinder motor that weighs about 500lbs. What are some of the lightest cars that we can fit a 10 inch tire under just notching the frame (can change fender shape too)? Fabrication is no problem. Only aftermarket fiberglass can be the hood. He doesn't care what make or model it is and it is a drag only deal. We are puting a class legal ladder bar setup under it with a full 25.5 chassis. Ideas would be greatly appreciated. Sorry this is not BBF related.
A little Help! Empty Re: A little Help!
Post  DILLIGASDAVE July 21st 2010, 12:34 am
If your talking American made, small, & fairly light weight your probably going to have to look at something older like a Pinto, vega, (if you can find either) or the boxy 80's Escorts. What "6 cylinder" does he have? Are we talking straight 6, or V6?
I might be crazy but I have always wondered what the old torquey Ford 300 straight 6 truck engines would do as a drag engine.
Post  res0rli9 July 21st 2010, 1:21 am
Back in the late 60's when I lived in Va. and guy from MD. cant remember his now, he had a ford 300 6cyl. with 2 Boss 302 heads that one cyl. cut off each one and welded the two together on it . it was in a little bantom and ran in 5s in the 1/8mil.
Post  schmitty July 21st 2010, 3:28 am
DILLIGASDAVE wrote:I might be crazy but I have always wondered what the old torquey Ford 300 straight 6 truck engines would do as a drag engine.
I ran the EFI version in my mud truck one year and got beat all over the place. Lots of tq, but the hp was way down, so I could always spin the tires, but not real fast. Evil or Very Mad
Post  Race Ready Fabrications July 21st 2010, 3:54 am
I got a buddy that runs a maverick witha 300 with a jerico behind it. It runs 6.90's in the eigth and thats on the back bumper through two gears.... Cool
Post  billandlori July 21st 2010, 5:21 am
There was a car that ran up here called The Pepper Box and he was running a Ford 6 in a row. It had 6 stacks and sounded pretty wierd, but was fast!!
Bill
Post  whatbumper July 21st 2010, 11:08 am
yeah it's a straight six. it will be efi with a 76mm turbo.
I thought about a Maverick. My old bracket car weighed 2450lbs and I could have taken a lot more weight out of it. It had an aluminum headed 302 with a C4 trans. It only had a MS 4pt cage and all of the factory sheet metal was there. That factory hood is heavy. leaf spring with slapper bars and all factory brakes
I was thinking a Maverick with:
fiberglass hood
9 inch or 8.8 (whatever I can buy fully built cheaply)
aerospace brakes on all 4 corners
25.5 CM cage
cut out ALL unneeded sheet metal
2 aluminum seats
powerglide (I know we will have enough low end torque)
air to air intercooler with minimized tubing
holeshot wheels
minitubbed-basically backhalf the car but leave the factory frame rail and replace the sheet metal with aluminum
small aluminum radiator
only accessory will be waterpump and alternator
What else would be beneficial?
Post  maverick July 21st 2010, 7:48 pm
Doesn't anybody remember Bruce Sizemore's "Preparation H" H/Gas Maverick? Ford truck 6, cut Boss 302 head.....NHRA record holder.....one badass 6-popper Maverick. Cool Google that one.
Post  Lem Evans July 21st 2010, 7:53 pm
Yes Smile
Post  DILLIGASDAVE July 21st 2010, 7:55 pm
Gas or alcohol? If you went with alcohol wouldn't you get to ditch the intercooler & save some more weight? A Maverick can be fairly light as a back half. But I wonder how something like the first Probe body style would compare weight wise as a back half.
Hard to tell which body would really push the least air as a back half. The Probe is super swoopy, but the Pinto & vega have a small frontal area too cuz their so narrow. The boxy Escort & the blunt nose Maverick are probably pushing the most air. But the plus for the Maverick is it has miles of rear fender/rear roof line for tons of slick & wheel tub room.
Post  maverick July 21st 2010, 7:59 pm
I was at the starting line with my cousin when Sizemore trailered Jim's E/Altered at the 3rd annual Pop Rod Championships......I think that was 1834....or maybe 1972. Rolling Eyes
Post  DILLIGASDAVE July 21st 2010, 8:05 pm
I remember reading old articles about CJ Batten furnace brazing sections of either Boss 302 or 351-C heads together to make a straight 6 head. But I don't remember if it was for the 300 6cyl.
Post  maverick July 21st 2010, 8:21 pm
I believe it was, Dave. That trick got real popular in the early 70's. My cousin was itching to put a 300 Ford in his altered....the injected Dodge "bent 6" was getting its ass regularly kicked by the 300's. He kept watching for a Ford engine to buy but all the racers had 'em cleaned out of the boneyards. He collected all the necessary pieces (Hilborns and all) except the engine core....then he died. Crying or Very sad Woulda been a cool car, too.
Post  whatbumper July 21st 2010, 9:37 pm
no alky, against the rules. Have to keep the factory frame rail but can notch the hell out of it though. I will not have to take much out though to fit the allowable tires which is the biggest of a 28x10.5.
I just received word on clarification of some rules. Can not alter the firewall or floor from the door jam forward except for bars. Can NOT change the front suspension from factory form. I can rebuild it but can't change it to a Mustang II or Fox style. Ladder bar is the standard rear suspension in the class but can run factory style. Has to meet the NHRA "rules" too. I said that very loosely. Mainly the safety stuff. Has to keep the factory dash.
He has not told me what organizations but keeps giving me rules. I have a feeling what classes but am not for sure. I am waiting until Sept to start on the build so I have time to learn more about what it needs to be.
What race weight can the early Falcons get to?
Post  69F100 July 21st 2010, 9:40 pm
Ford EXP
Post  cool40 July 21st 2010, 9:49 pm
how about one of those old capri's? were they english made or something like that? you know the one that was kinda ugly but look like they have a long frontend.they do have a strut type front suspension and a lot of room under the hood,sorry i'm thinken bbf room. Smile
Post  whatbumper July 21st 2010, 10:11 pm
cool40 wrote:how about one of those old capri's? were they english made or something like that? you know the one that was kinda ugly but look like they have a long frontend.they do have a strut type front suspension and a lot of room under the hood,sorry i'm thinken bbf room. Smile
anyone know where I can find a 1969-1974 Ford Capri Mk1. I think that will be a winner if we can get our hands on one.
Post  bb429power July 21st 2010, 10:19 pm
anyone know where I can find a Ford Capri Mk1. I think that will be a winner if we can get our hands on one.
Here's one me and my dad worked on. Engine was getting machined and built at his shop and we were swapping out labor. Did the bodywork and primer. My dad made the cowl all custom and flat. He also made a custom panel, I'll find a picture for you.
http://www.network54.com/Forum/237168/thread/1267218691/last-1267218691/1985+ASC+McLaren+Capri+Drag+Car
bb429power
bb429power
Post  bb429power July 21st 2010, 10:25 pm
EDIT-never mind Laughing
bb429power
bb429power
Post  cool40 July 21st 2010, 11:04 pm
^^ that aint the kinda capri i'm talken about. Laughing
Post  bb429power July 21st 2010, 11:16 pm
cool40 wrote:^^ that aint the kinda capri i'm talken about. Laughing
Oh $#!t I wasn't even paying any attention. Embarassed Way off Mad
bb429power
bb429power
Post  cool40 July 21st 2010, 11:29 pm
74 would be a year i know they were made.
Post  whatbumper July 22nd 2010, 12:03 am
cool40 wrote:74 would be a year i know they were made.
know where any are???
Post  cool40 July 22nd 2010, 12:14 am
gotta be some in your part of the country.i guess the price of scrap metal can thin out the "project"cars,lol.i have saw one of those running in super pro in huntsville AL. years ago,i got all happy when i noticed it in the lanes,then i saw the big brand x stamp on the hood and walked on by. Laughing
