External Pump Oil Pan for Fox, 6-bolt Valve Covers, Moroso Remote Filter Mount
External Pump Oil Pan for Fox, 6-bolt Valve Covers, Moroso Remote Filter Mount Empty External Pump Oil Pan for Fox, 6-bolt Valve Covers, Moroso Remote Filter Mount
Post  gryphon68 July 22nd 2010, 1:38 pm
Moroso BBF Fox Oil Pan with -12AN External Oil Pump Pickup. Has been massaged to fit 4-bolt #5 Main. Was seeping at the rear drain plug when last installed, I believe it just needs a new crush washer. $150+shipping
Also have another Rear Sump Moroso Pan with wide kick outs on rear sump. Nice baffle/screen Front of pan is 5", will fit in Fox. Has 1" NPT bung on Driver's side for Moroso In-Pan Oil Preheater. This pan has some cracks in the corners that have been brazed and cracked again. This also has a -12 external pump pick-up. $100+shipping.
Moroso 23766 Remote Oil Filter Mount. Blue Anodized. -12 In and Out. $50+shipping
BBF Cast Aluminum Valve Covers - 6 bolt (4 down/2 up). Canted Outside wall. Fit well in a Fox. Engine Systems logo. -12AN Breather/Vacuum Pump fitting. 1/4" NPT hole for vacuum bleed or pressure sensor port. $75+shipping
PM if interested please.
gryphon68
External Pump Oil Pan for Fox, 6-bolt Valve Covers, Moroso Remote Filter Mount Empty Re: External Pump Oil Pan for Fox, 6-bolt Valve Covers, Moroso Remote Filter Mount
Post  138 July 22nd 2010, 3:10 pm
pm sent
138
Post  TravisRice July 22nd 2010, 3:35 pm
PM sent on valve covers. Very interested / Travis
