Using a soild roller lifter on a hydraulic Roller cam.
Maddmattmustangs
Would this cause major wear on the lobes??
Re: Using a soild roller lifter on a hydraulic Roller cam.
Friend of mines motor. This ones got me stumped. I don't see why it would have happened.
Maddmattmustangs wrote:Would this cause major wear on the lobes??
Not a problem IF the lash is kept very tight ... around .004"/.006" or so.
It is done "all the time" on street/strip builds where you don't want a lot of valve spring pressure.
rmcomprandy wrote:Maddmattmustangs wrote:Would this cause major wear on the lobes??
Would a lash around say .020 cause the lobes to wear badly at the top? The lobes are almost flat at peak. Look more like bricks instead of tomb stones
NOPE ... not at the top of the lobe unless the roller came off. Some roller cam lobes are pretty flat to "begin with".
I'll have to get a pic but the lobes all chewed up. When I checked out the rollers on the lifters i found that all the ones that had been on damaged lobes were all locked up tight. Think I found the culprit.
wayne rhodes- Posts : 34
Maddmattmustangs wrote:I'll have to get a pic but the lobes all chewed up. When I checked out the rollers on the lifters i found that all the ones that had been on damaged lobes were all locked up tight. Think I found the culprit.
Sounds like the rollers siezed and wiped your buddys cam, time to get a new cam and lifter kit. Also a magnetic drain plug and filter wrap would be good insurance as well.
torkair- Posts : 404
Replace the oil and filter and run a magnet along the pan first. Then get the magnetic plug and filter wrap, JMO.torkair wrote:Maddmattmustangs wrote:I'll have to get a pic but the lobes all chewed up. When I checked out the rollers on the lifters i found that all the ones that had been on damaged lobes were all locked up tight. Think I found the culprit.
bb429power- Posts : 3129
I curupted him.. Were just gonna beef up the engine some more and do a total overhaul
» Hydraulic roller lifter adjustment.
» Crane/Ford Racing Hydraulic Roller Lifter Problem, Warning...
» Using Hydraulic roller lifters on the Comp XR292 R-10 Xtreme Energy Solid Roller cam?
» hydraulic roller cam with solid roller lifters
» Hydraulic roller lifters !
