16 Volts
16 Volts
is any one that is using a 16 volt battery, using a voltage drop to power any other acceseries
Larry Williams- Posts : 884
Re: 16 Volts
I run a 16/12 volt battery. The only thing hooked up to the 12v side is the LM1
Curt- Posts : 2791
Re: 16 Volts
all 16 here, I use a sep. 12v batt (ATV) just for the primperplus sol and pump (cheap pump dont like it)
Re: 16 Volts
I got the 16 with the 12 post , but everything I run is on 16.
KY JELLY- Posts : 1530
Re: 16 Volts
richter69 wrote:all 16 here, I use a sep. 12v batt (ATV) just for the primperplus sol and pump (cheap pump dont like it)
MR Gasket has a nice looking pump. part number # 12 S
Last edited by Larry Williams on July 27th 2010, 11:35 pm; edited 1 time in total (Reason for editing : add information)
Re: 16 Volts
Super hero uses the breast pump that came at the baby shower.
Curt- Posts : 2791
Re: 16 Volts
Once you go 16 volt you will never go back. All of my stuff runs on 16 volt and I use the stock head lights, tail lights, etc. with now problems at all.
Re: 16 Volts
the only problem I seem to have is with fuel pressure. its 3 pounds higher with the 16 v than the 12
