fox mustang 8.8 rearend build up questions
tiger
fox mustang 8.8 rearend build up questions Empty fox mustang 8.8 rearend build up questions
Post  tiger July 30th 2010, 11:04 am
I am building an 8.8 rearend for my bbf powered mustang. I hope the engine is 500 hp, and it will have a 3,000 stall converter in it with 3.73 gears, no transbrake. Will 31 spline aftermarket axles be strong enough?
I plan on welding the tubes, putting a girdle on it, factory locker, c-clip eliminators, 31 spline moser axles. Is this enough or should I put 33 spline in it, and will the factory 31 spline locker handle it?
tiger
fox mustang 8.8 rearend build up questions Empty Re: fox mustang 8.8 rearend build up questions
Post  Mike R July 30th 2010, 7:14 pm
Since you're buying axles I would go with 9 inch ends on the housing instead of c-clip eliminators, they tend to leak. You could also narrow the housing a few inches while you're at it for better tire clearance. Have the ends installed and the tubes welded by someone with a jig then you'll be sure it's straight, the tubes will pull when you weld them. I would say no to the factory posi and go with a spool or an after market locker. 31 spline's will work but since you're buying new axles bigger is better it just depends on what you can afford. It's better to spend a little more now than to have to do it over again when it breaks.
Post  Big block fox 339 July 30th 2010, 8:47 pm
When I bought my stuff I just went 33 spline it was the same price I went with strange c-clip elems and no leaks
Big block fox 339
Big block fox 339
Post  GTmustang July 31st 2010, 4:23 pm
My Strange C-Clip eliminators leaked after I ran them for awhile, so I had 9" ford ends put on and the housing narrowed. This is much better than the c-clip eliminators!
Gary
GTmustang
Post  Notch 501 September 24th 2010, 4:45 pm
ran c-clips all summer long with stock 28 spline axles my 60 fts are only 1.6 so im not leaving hard no leaks, just keep burning out the friction discs time for axles and a spool
Notch 501
Notch 501
Post  sg86coupe September 27th 2010, 7:53 pm
33 spline much better ideal
9" ends also better ideal, welding up axel tubes a must, but will draw tubes off center lines.
Putting 9" ends on with a jig after welding up axel tubes will true back up.
sg86coupe
