700r4 isssue
700r4 isssue
who makes a full manual valve body for the 700r4 tranny ? and is it a drop in deal or does it need to be tore apart ? thanks..and the tranny is 100% new..good clutches, coverte servo and shell..etc...we had it behind a stock 350 and it shifted great, built a new motor and swap the injection to a carb . it shift 1-2 easy but does weird stuff into drive, like its out of fluid but its not, i think it may be the adjust of the tv cable , so we want to just by pass the cable
johndickjr- Posts : 896
Re: 700r4 isssue
I believe TCI does. I had a cheetah mvb in a 700r4 once. FWIW I could not get the tranny to last however.... no matter what the guys building it claimed. I crapped it 3 times in 1 season before literally tossing it in a dumpster. This was behind a 500hp 383sbc with a 200 hit of nos. Swapped in a th350 that would last a full season before needing a go thru.
4thHorseman- Posts : 400
Re: 700r4 isssue
If your drag racing the 700r4 isn't a good choice. it tough enough keeping those things together in the street with something a little hot.
Re: 700r4 isssue
its not mine and i have told him this but you know how these chevy guys are, he had a vette servo installed in it and now he thinks its bullet proofdfree383 wrote:If your drag racing the 700r4 isn't a good choice. it tough enough keeping those things together in the street with something a little hot.
Re: 700r4 isssue
all that does is allow it to shift into OD under full throttle....... Whats the matter with a TH350??? Not enough gears?
Re: 700r4 isssue
im serious he thinks its bullet proof ,and it is new so , balo..bla..bla..he is a dumb ass chevy guy, i tired to help as much a possibly, but he would not listen at all, he had all his chevy Buddie telling him this and that, now he thinks the car is a low 11 sec car, i made a pass in it , best it ran was 13.61 , once he gets it all worked out it will go 12.20 range, which is not bad , the motor is pretty cheap build, if he would listen to me it would be a 11.90 car,dfree383 wrote:all that does is allow it to shift into OD under full throttle....... Whats the matter with a TH350??? Not enough gears?
Re: 700r4 isssue
It will not last ! These trans run hotter than any other trans stock and have a boat load of issuses that GM cant fix.
whitefield- Posts : 2244
Re: 700r4 isssue
i know..i know..we went trough this on my brothers s10, he spend close to 3000.00 on his before it would hold up, normal chevy guy thinks his chit is tough and its junk, not a bad motor but still a turdwhitefield wrote:It will not last ! These trans run hotter than any other trans stock and have a boat load of issuses that GM cant fix.
