400 help
400 help
Well I got my motor back from the machine shop, all cleaned up with new bearings and plugs installed, also got the crank polished and new bottom end bearings and rings ready to go in but since I've had everything cleaned out I was thinking of taking the oil pump apart, cleaning it up and reusing it or getting a new pump and chucking the old one in the trash. Any help with this would be greatly appreciated.
torkair- Posts : 404
Re: 400 help
whats a new one cost..?? $20-30
johndickjr- Posts : 896
Re: 400 help
After checking around a new pump is in the $25 range, so just gonna get a new one and play with the old one for the experience of doing it. As for assembly, I've got all the pistons ringed and ready to go just was wondering what the prefered method of oiling them before putting them in is, I've seen them dunked in a coffee can full of oil but I don't want burnt oil on the crowns so let me know what you guys prefer to do when putting the slugs back in.
Re: 400 help
I dunked mine in a coffee can of oil, but I didn't fire mine right away and I wanted make sure it had lots! You could just get a squirt can of oil and give the rings a few shots.
Bill
Bill
billandlori- Posts : 2081
Re: 400 help
billandlori wrote:I dunked mine in a coffee can of oil, but I didn't fire mine right away and I wanted make sure it had lots! You could just get a squirt can of oil and give the rings a few shots.
Bill
Was thinking of doing that, but wondering what kind of oil to use such as regular engine oil or maybe a few drops of lucas oil stabilizer in the ring gaps, then tighten the ring compressor and give the slugs a few good turns before dropping them in just to get some good coverage.
On a side note my brother keeps saying put them in dry and the rings will seat within the first few minutes of operation, but this seems like suicide for a new motor, any thoughts?
Re: 400 help
Oil can, give a squart or two to the rings and one on each skirt and use your finger to rub it around Hit the pin with a shot and install. No need to dunk them its to messy.
