FE ?
jm
FE ? Empty FE ?
Post  jm August 5th 2010, 12:14 pm
i have a 332 fe. i was wondering and not sure, but the 332&352 has the same block and rods,but different crank and pistons???
jm
FE ? Empty Re: FE ?
Post  bbf-falcon August 5th 2010, 2:25 pm
the crank in a 332 is 3.30 stroke and the stroke in a 352 is 3.50. the bore is the same rods are the same but the pistons are different.As far as looking at them,the 332 is light green and the 352 is a robin egg blue. If you need parts for either,just let me know Smile
FE ? Empty Re: FE ?
Post  dfree383 August 5th 2010, 2:28 pm
Didn't the early FE's have different rod Lengths?
FE ? Empty Re: FE ?
Post  jm August 5th 2010, 3:49 pm
bbf-falcon wrote:the crank in a 332 is 3.30 stroke and the stroke in a 352 is 3.50. the bore is the same rods are the same but the pistons are different.As far as looking at them,the 332 is light green and the 352 is a robin egg blue. If you need parts for either,just let me know Smile
thanks for the info. yes this motor was a light green&2 barrel carbed. the customer and i are thinking of swapping out the crank to a 352 and building it with a 4barrel carb set up. the number on the crank are-#5752421. is this the 332?
jm
FE ? Empty Re: FE ?
Post  jm August 5th 2010, 3:52 pm
dfree383 wrote:Didn't the early FE's have different rod Lengths?
im not sure.. but the rods in this motor are different looking than the 428 and 390's that i have built in the past bounce
jm
FE ? Empty Re: FE ?
Post  dfree383 August 5th 2010, 9:21 pm
Why not swap in a 390 rotating assembly???
FE ? Empty Re: FE ?
Post  Diggindeeper August 5th 2010, 9:27 pm
did the 332's not have a somewhat lower deck height then the rest of the FE's?
Diggindeeper
Diggindeeper
FE ? Empty Re: FE ?
Post  LivermoreDave August 5th 2010, 9:49 pm
You may find answers to your question(s) at this site.
http://www.network54.com/Index/10214
Dave.
LivermoreDave
FE ? Empty Re: FE ?
Post  whatbumper August 5th 2010, 10:13 pm
Diggindeeper wrote:did the 332's not have a somewhat lower deck height then the rest of the FE's?
All FE motors have a 10.17" deck height from the factory. The 332 and the 352 share the same bore but the 332 has a shorter stroke. When you restore Edsels on the side you figure out all sorts of cool stuff about FE, FT, MEL, & Y-block engines.
FE ? Empty Re: FE ?
Post  cool40 August 5th 2010, 10:46 pm
332-352 deal sounds like a 429-460.
FE ? Empty Re: FE ?
