procomp nitrous plate ?
+11
SLOWnSTEADY
Maddmattmustangs
fatal addiction
powerstrokeace
Barney
89lxcoupe
15 posters
Page 1 of 2
Page 1 of 2 • 1, 2
any good ! they claim up to 250 shot and its a 40 hole plate !
89lxcoupe- Posts : 60
Re: procomp nitrous plate ?
yeah it is good for about 1.80 a lb scrap weight.....to add to beer cans......
the Coug- Posts : 3055
well if it performs as good as all the other products.............
richter69 wrote:well if it performs as good as all the other products.............
you wont keep it off the rear bumper
res0rli9- BBF CONTRIBUTOR
Barney wrote:Scary!!!
yeah what next safety belts made out of shoe string or felt?
i know some of there products are good and bad, just wondered if any one has flowed one or tried one in person. i wonder if it compares to a holley plate. they copy everything else holley makes ?
89lxcoupe wrote:i know some of there products are good and bad, just wondered if any one has flowed one or tried one in person. i wonder if it compares to a holley plate. they copy everything else holley makes ?
personally if you wish to run NOS buy a good plate not some off the wall fly by night deal like (ProComp)
JMHO
If you really want to spray some thing... Talk to the guy's at Induction Solutions and follow everything they say and it will work. Pass on the ProComp stuff
Ace
powerstrokeace- Posts : 1496
I wouldn't wear a Pro-Comp cap if they made one.
whatbumper- Posts : 3024
Your nitrous plate isnt somewhere to save a buck. That little bit of saving could cost you a TON of money in a matter of seconds, literally. Nothing like melting pistons, or kicking out a rod because of a cheap plate. If Procomp made Airplanes, would you fly in one?
i understand, i was just wondering if it performed like the cheater plate since they copy the holley brand , but they do make some good products ! i have there roller rockers and they look just as good as harland sharps and are quiet so far and i have there holley black knock off pump and regulator. so far so good ! i have everything but the plate. i will look at induction solutions plates !
89lxcoupe wrote:i understand, i was just wondering if it performed like the cheater plate since they copy the holley brand , but they do make some good products ! i have there roller rockers and they look just as good as harland sharps and are quiet so far and i have there holley black knock off pump and regulator. so far so good ! i have everything but the plate. i will look at induction solutions plates !
You aren't going to find much Pro Comp "love" on this site, you get what you pay for. Good luck with it though, you'll need it.................
Nevs- BBF CONTRIBUTOR
Pro Comp = cheap They copy which makes you feel like you are getting a really good deal (NOT)99.99% is junk if it has moving parts buy the real thing.....
you will be glad you did
i agree pro comp stuff is junk but this one kinda stumps me? people make spray bars ''at home'' all the time for their tunnel rams ''i'm not sticking up for pro comp'' but as long as it has the right size holes, and the right jets,and the right fuel pressure, why wouldn't it work?? oh by the way i run a nos system!!!
fatal addiction- Posts : 433
whatbumper wrote:I wouldn't wear a Pro-Comp cap if they made one.
Probably fall off or fade when it it's the sunlight.
WHY IS THERE A BUG ON MY SCREEN!!!!!
I actually tried to flick it off then realized what is was
fatal addiction wrote:i agree pro comp stuff is junk but this one kinda stumps me? people make spray bars ''at home'' all the time for their tunnel rams ''i'm not sticking up for pro comp'' but as long as it has the right size holes, and the right jets,and the right fuel pressure, why wouldn't it work?? oh by the way i run a nos system!!!
I rekon if you "looked it over" and "checked it out"...................but then again those buy stuff because of price might not know what to look for in the first place.
Maddmattmustangs wrote:WHY IS THERE A BUG ON MY SCREEN!!!!!
Pretty funny isn't it. My brother had it on his sig on another forum and it pissed me off so much I thought I would share it. LOL
FWIW... I have been running a ProComp plate on my Small block for over a year now. Using a 1.9 nitrous jet and a 2.0 fuel jet I gained just over 200 at the wheels. No idea what those jets are suppose to be though honestly. just went with the biggest nitrous jet in the kit and then a slightly bigger fuel jet because i don't know a ton about nitrous and thought that would be a little "safer".
That's running a Holley blue @ 10psi for the fuel solenoid, 110 octane, 900~psi bottle pressure on a stock 5.0HO long block, single plain hi-rise intake, full length headers, MSD ignition, Holley 625cfm carb etc...
SLOWnSTEADY- Posts : 53
Me personally I would rather pick up a used NOS or equivalent plate. I see they are using alot of procomp stuff in mm&ff but im sure that is bc they send it to them free to try. When they put the parts on running cars and beat the balls of them and they hold up than Ill think about using the stuff. I dont have the money to buy stuff once let alone twice.
droppedf100- Posts : 176
isn't 10 psi @ the fuel solenoid a little high??SLOWnSTEADY wrote:FWIW... I have been running a ProComp plate on my Small block for over a year now. Using a 1.9 nitrous jet and a 2.0 fuel jet I gained just over 200 at the wheels. No idea what those jets are suppose to be though honestly. just went with the biggest nitrous jet in the kit and then a slightly bigger fuel jet because i don't know a ton about nitrous and thought that would be a little "safer".
fatal addiction wrote:isn't 10 psi @ the fuel solenoid a little high??SLOWnSTEADY wrote:FWIW... I have been running a ProComp plate on my Small block for over a year now. Using a 1.9 nitrous jet and a 2.0 fuel jet I gained just over 200 at the wheels. No idea what those jets are suppose to be though honestly. just went with the biggest nitrous jet in the kit and then a slightly bigger fuel jet because i don't know a ton about nitrous and thought that would be a little "safer".
IDK.... been working fine for me thus far though. When I was running the carb/fuel solenoid off the same pump at 4psi I was using a 2.3 fuel jet with a 1.6 nitrous and gained like 75RWHP less than with this setup so. "If it ain't broke, don't fix it" I guess...
droppedf100 wrote:Me personally I would rather pick up a used NOS or equivalent plate. I see they are using alot of procomp stuff in mm&ff but im sure that is bc they send it to them free to try. When they put the parts on running cars and beat the balls of them and they hold up than Ill think about using the stuff. I dont have the money to buy stuff once let alone twice.
yeah i may do that i have been on ebay looking ! but i still don't know how they could mess up a nitrous plate ?
How can they mess up the other stuff they have totaly butchered??? Thats the mistery !!89lxcoupe wrote:droppedf100 wrote:Me personally I would rather pick up a used NOS or equivalent plate. I see they are using alot of procomp stuff in mm&ff but im sure that is bc they send it to them free to try. When they put the parts on running cars and beat the balls of them and they hold up than Ill think about using the stuff. I dont have the money to buy stuff once let alone twice.
whats it run on the spray ?
Page 1 of 2 • 1, 2
» Wtb....Top Gun Nitrous Plate
» Nitrous outlet Stinger plate
» 2.125 throttle bore nitrous plate
» small nitrous line and a bigshot plate
» NOS DOMINATOR NITROUS PLATE
Page 1 of 2
