c6 shifter linkage position and pattern.
is the linkage strait down and pattern front to rear P-R-N-3-2-1 on all c6 transmissions ? mine is from a 76 lincoln long tailshaft that i converted to mid car shaft and housing !
89lxcoupe- Posts : 60
Re: c6 shifter linkage position and pattern.
The factory linkage points to the front in park and in 1st it still points to the front a little,if you use a aftermarket lever you can move it around where you want as long as it works all the gears.
nuclearcobra- BBF CONTRIBUTOR
» Reverse pattern shifter on standard pattern trans?
» How to set linkage on PG with TCI shifter?
» shifter mounted gear position switches
» Fox body shifter and linkage
» Need a good shifter for c6 reverse pattern
