used rotating assembly
new2460
i bought a used rotating assembly with forged pistons. it had about 50 passes from truck pulling. can i reuse the rings or should i replace them? how do you tell if a ring is bad? thanks p.s. sorry for the dumb question.
new2460- Posts : 195
Re: used rotating assembly
Its easier to replace them now than find out they are worn out and its best to replace them since you are putting them in a new bore, if the existing motor was going back together (as taken apart) at that much use you could reuse them if their where no problems noticed.
in short, Replace them.
Yea, like Dave said. especially on a New hone job. do it right
If the ring is not going back into the same bore it came out of ... replace it.
Rings are cheap, replace them!
torkair- Posts : 404
You say "BAD RING"......
If it looks crestfallen.......it knows it's been naughty.....
Mark O'Neal- Posts : 286
Mark O'Neal wrote:You say "BAD RING"......
95lightiningguy- Posts : 570
» rotating ass. push rods msd pistons ''''c-460 pistons added to rotating assembly''''
» DELETE Thanks
» BBF used N/A rotating assembly and cam
» Rpm rotating assembly for sale , and misc. take a look
» 460 Parts for sale
» DELETE Thanks
