Best way to check quench ???
Best way to check quench ??? Empty Best way to check quench ???
Post  bb429power August 16th 2010, 9:38 pm
I tried checking my quench, I know the depth mic. is good. I tested it on the deck a couple times, but when I check how far the piston is in the hole I get some weird numbers. I asked for it to be zero decked but I'm not sure if it was. 10 or 5 thou was shaved off the deck though, but I was getting like 16, 18 thou in the hole Suspect So what would you say is the best way to check it? Keep turning it over (very slightly) until you get the smallest number?
bb429power
bb429power
Best way to check quench ??? Empty Re: Best way to check quench ???
Post  DFI429 August 16th 2010, 11:53 pm
Set up a mag base w/ a plunge indicator on the piston & turn the crank with the piston going up until it stops
Then measure with your depth mic or use the plunge indicator like a surface gage (measure the step)
DFI429
DFI429
Post  bb429power August 16th 2010, 11:56 pm
EDIT-Thanks for the help. Very Happy I'll wait until I get my cam degreeing kit and use the dial indicator from that and my depth micrometer.
bb429power
bb429power
Post  DFI429 August 16th 2010, 11:59 pm
bb429power wrote:Ahh, okay. Could I just wait until I get my cam degree kit and use the dial indicator with the magnetic base to check it?
Yeah - just turn the mag off and use it like a surface gage if you don't have one. Zero it out on the deck and slowly move over to the piston top while keeping the mag base square & on deck Cool
DFI429
DFI429
Post  bb429power August 17th 2010, 12:05 am
Okay, thanks. I'll have to wait a little bit until I get the degree kit. I want it but I'm working on AT the machine shop to pay off the machine shop bill so I can't get it right now. I'll have to check my funds, call my people, and have my people call the people at summit Laughing
bb429power
bb429power
Post  DFI429 August 17th 2010, 12:13 am
bb429power wrote:Okay, thanks. I'll have to wait a little bit until I get the degree kit. I want it but I'm working on AT the machine shop to pay off the machine shop bill so I can't get it right now. I'll have to check my funds, call my people, and have my people call the people at summit Laughing
Save a few more pennies and hit up Lem for the Jomar kit... I hear it's way better quality than the Scummit setup... with better service to boot Cool
DFI429
DFI429
Post  bb429power August 17th 2010, 12:49 am
Any idea on how much that would run me? I was going to get this one, I want a bigger wheel for obvious reasons.
http://www.summitracing.com/parts/SUM-G1056/
bb429power
bb429power
Post  IDT-572 August 17th 2010, 10:41 am
When you check the piston to deck, make sure the dial indicater is dead on top of the wrist pin. That way piston rock wont get into your measurement.
Post  bb429power August 17th 2010, 11:17 am
I'll make sure to do so, thank you.
bb429power
bb429power
