whats with new tack and 2 step not being equal on brake?
whats with new tack and 2 step not being equal on brake? Empty whats with new tack and 2 step not being equal on brake?
Post  Ed501 August 22nd 2010, 11:21 pm
I tried differant chips and tac show higher rpms, sometime 500 sometime 1000 past chip. Its a memory tac from Auto meter and wasnt cheap. Has good grounds . Is it normal to bounce past some? Boy it was loud with a 4200 chip and tac around 5000 on transbrake. Question
Ed501
whats with new tack and 2 step not being equal on brake? Empty Re: whats with new tack and 2 step not being equal on brake?
Post  Ed501 August 23rd 2010, 1:00 am
tommarrow i will take off 2 step and try low chip in 6al box and watch tac. Motor sure sounded ruff on two step whole car was shaking and everything in garage was falling,lol ED
Ed501
Post  bbf-falcon August 23rd 2010, 7:52 am
Most likely Bad chip,it's not unusual. I always liked the dialachip for the low side.You can set it where ever you want it.
Post  69F100 August 24th 2010, 8:22 pm
Ed let me know what you find I have a autometer with recall and memory in it.It does the same thing I have tried to change the setting with no luck.I could tell my tach was off before I put the msd in mine.I put a 3000 chip and my tach would go to 5000 one time then again it might go to 4000 never would stop at 3000 with the chip.When idling mine down if i went anything under 1100 the engine would shout off an I tell you the engine is not idling at 1100.As soon as I get everything hooked back up I am going to take the old Mallery tach out of the 69 and try it and see what it reads.
Jim
