Dyno tested the new Pro Systems carb...
+8
Diggindeeper
Larry Williams
12 posters
Dyno tested the new Pro Systems carb... Empty Dyno tested the new Pro Systems carb...
Post  rmcomprandy August 24th 2010, 11:08 pm
I not sure you guys would want to know the results because it was on a 800 Horsepower, 7,500 RPM, B.B. Chevy 496. If this bothers you then don't go any further and just forget it.
Peak horsepower moved higher to 7,300 RPM Vs. 7,100 RPM with a 4150 Holley #0-80513-1 and showed a 23 horsepower increase.
Peak torque was at the same 5,300 RPM and was 16 lb/ft higher.
Part throttle response wasn't bad at all, once you got to a higher than idle speed; no big air/fuel ratio holes were noticed either.
Actual numbers witheld by engine owner's request.
Dyno tested the new Pro Systems carb... Empty Re: Dyno tested the new Pro Systems carb...
Post  schmitty August 24th 2010, 11:49 pm
Was this the SV-1? What size was the 4150? Cool
Post  Larry Williams August 25th 2010, 12:01 am
1000 cfm 4150 HP Carburetor
Gasoline
Progressive mechanical secondaries
30cc primary and 50cc secondary accelerator pumps
Spun-in double-step down leg boosters
More info on Holley 0-80513-1
Larry Williams
Larry Williams
Post  rmcomprandy August 25th 2010, 9:48 am
schmitty wrote:Was this the SV-1? What size was the 4150? Cool
A well tuned 1,000 cfm Holley carb and the new 4" throttle bore Pro System's, (whatever it's called).
Post  bbf-falcon August 25th 2010, 11:21 am
Thats the SV1.I like it. I just can't afford one right now. I read a little about them but,I didn't notice a listing for one for Alcohol.
Post  G-Code August 25th 2010, 11:36 am
It would be interesting to know what a 7,500 rpm 800 hp 496" engine would do with a 1050 or 1150 Dominator.
I take it this carb bolts directly to the 4150 manifold so it could be considered the best carb for that manifold.
Oh yeah.....this post is worthless with out pictures Wink
G-
Post  rmcomprandy August 25th 2010, 2:57 pm
G-
Then it's gonna stay worthless ... sorry I brought it up.
You can't simply take pictures of someone else's engine on the dyno without their approval ... this was supposed to be secret and I've probably said to much already.
Post  Diggindeeper August 25th 2010, 5:27 pm
23 and 16 is a pretty big gain with all else being equal.
Diggindeeper
Diggindeeper
Post  G-Code August 26th 2010, 2:03 am
Oh yeah.....this post is worthless with out pictures Dyno tested the new Pro Systems carb... Icon_wink
G-
Well hopefully your Chevy customer doesn't visit Fords sites to often. Nice increase though.
G-
Post  bruno August 26th 2010, 5:40 am
so whats your opinion on this carb Randy ....do you like it ?? would you use it on your emc engines ?
http://WWW.CKRME.COM
Post  richter69 August 26th 2010, 8:12 am
The 4150 makes the SV1 look like a HeRo.................. cheers
Post  Bret Powell August 26th 2010, 9:58 am
So Randy... The big question is... Were you impressed? How well did it idle?
Bret
Bret Powell
Post  rmcomprandy August 26th 2010, 11:29 am
Bret Powell wrote:So Randy... The big question is... Were you impressed? How well did it idle?
Bret
It idled well and just off idle there was a slight sag in the part throttle but, the fuel ratio remained livable. It has one hell of a pump shot so if any type of milage is your goal, then this isn't it.
I went into this test SKEPTICLE so, it did impress me somewhat.
Nick ... The test rpm started at 4,500 RPM so, I have no idea how it would perform all the way down to 2,500 RPM and in the EMC that is critical; peak power alone means almost nothing in that contest.
DRAG racing is a different story.
Post  rmcomprandy August 26th 2010, 11:31 am
Removal...?
I edited the part to Nick and it double posted it.
Post  jones August 26th 2010, 12:40 pm
Can you say how many cfm Patrick set this SV1 up for? Was it a 1,000cfm vs 1,000cfm etc...?
jones
Post  rmcomprandy August 26th 2010, 10:16 pm
jones wrote:Can you say how many cfm Patrick set this SV1 up for? Was it a 1,000cfm vs 1,000cfm etc...?
I have no idea.
Post  bbcoupe August 27th 2010, 4:51 am
Thanks heaps for sharing the info, and at some personal cost!
Took delivery of my 1150cfm SV-1 a few weeks ago and am eager to get it on the dyno when motor is finished soon.
Thanks,
Sean.
bbcoupe
https://www.youtube.com/user/coupe545
Post  feetfirst August 27th 2010, 4:14 pm
I have no idea.
Considering I have a 1400 cfm SV1, with a throttle bore of 4.52", and Randy mentioning the one He tested had a 4" bore, it would equate to around 1050 cfm range, give or take....
feetfirst
feetfirst
