Comp cams thumpr cams.....
Comp cams thumpr cams..... Empty Comp cams thumpr cams.....
Post  Maddmattmustangs September 2nd 2010, 8:41 am
Are these things worth anything for performance? Laughing
Maddmattmustangs
Maddmattmustangs
Comp cams thumpr cams..... Empty Re: Comp cams thumpr cams.....
Post  rmcomprandy September 2nd 2010, 10:24 am
Maddmattmustangs wrote:Are these things worth anything for performance? Laughing
For OEM type heads they work well ... and don't require a lot of valve spring which is nice for a DRIVEN street/strip car.
Post  Maddmattmustangs September 2nd 2010, 10:49 am
So you think one would work well for detuning a 410ci 10.3:1 compession Cleveland engine with worked over 4v closed chamber heads? I'm kinda wanting a more street friendly and show friendly cam now, with my recent updates to my next engine. Laughing
Wouldn't that cam profile make very broad power and tourque?
Maddmattmustangs
Maddmattmustangs
Post  IDT-572 September 2nd 2010, 7:27 pm
It will help......... They are ground on a 107. From my experience, we ran them for years, they like a narrow LSA.
The last one we ran was ground on a 100 LSA it performed the best of everything we tried. It's funny when you look in the cam book they list most all 4V Cleveland cams on a 108 or wider.
We tried a 98 LSA but ran out of intake valve to piston clearance. And decided to put the old cam back in.
We also set the cam in at a very early intake center line. Very early............
Post  69F100 September 2nd 2010, 8:57 pm
Matt what lift are looking for I ran a comp 292h in mine it was a 4v heads closed chamber I ran it on the street it had a real lopey idle ran it for 5 years before dropping a valve in it.
Post  Maddmattmustangs September 3rd 2010, 1:52 am
Nothing over .590 lift, I don't want to beat my valve seats up Laughing
I think I'll add the large thumpr can to my list
Maddmattmustangs
Maddmattmustangs
Post  69F100 September 3rd 2010, 9:10 am
Matt here is the one I ran I bought the k-kit http://www.summitracing.com/parts/CCA-K32-234-4/ I know they are more people here that has ran different cams but the 292h ran great for me.I ran 11.5-1 compression made little over 500hp
Post  Maddmattmustangs September 3rd 2010, 10:20 am
How fast did you run or did you run it at the track?
That cam does look very good considering what I'm flowing at that lift Very Happy
Maddmattmustangs
Maddmattmustangs
Post  69F100 September 3rd 2010, 12:51 pm
I ran it one night at tnt one time it ran the high 7's I think it was a 7.87 in the 1/8 in my 69f100 but the track did not have a long shut down back then I had drum brakes all the way around manual brake no power brake on top of that.I hit the brake after the 1st pass and the truck seem like it picked speed and the end of the track was coming up in a hurry and pine trees at the end. affraid So I loaded it back up and never carried it back after that. But it surprize the crap out of me the way it ran in the heavy truck. I had a 3000 stall c6 trans,4.10 gear with 28 10.5 slicks on it with 3/4 ton leaf springs out of a 64f100 and they are still under the truck.
