429 Hemi
+6
scottk
10 posters
429 Hemi
Hey guys,
Seems like a crazy question but were the 429 hemi's used in industrial applications? If so would these make for a good street engine? Aside from the heads is there anything I should look for to determine what it is? Anything to be aware of on these engines? This is another case of someone saying "I know a guy who has one of theses 429 hemi's cheap", so I thought I would check it out. What would they be worth?
Thanks,
Scott
Thanks,
Scott
scottk- Posts : 33
Re: 429 Hemi
429 Boss (hemi) were never used as irrigations unless someone put one on, but never heard of any, now Chrysler made a 392 Hemi that was used alot but it was all cast iron and HEAVY...
I have seen a bunch of FORD 427 Low risers used for Irrigation Engines. and some 460 industrials....
the Coug- Posts : 3055
Re: 429 Hemi
Scott,
To the best of my knowledge,,,,no they were never used in industrial applications. However, the old style Chrysler 354-392 Hemis were used in industrial applications and marine applications. For example, my uncle had a country sawmill and it had a 392 Chrysler industrial engine powering it. If you find an industrial Chrysler hemi it's probably worth buying at a reasonable price.
Hope this helps,
Charlie
Hope this helps,
Charlie
c.evans- BBF VENDOR SPONSOR
Re: 429 Hemi
Thanks guys for the responses. I really appreciate it. I hope to get over and look at it this weekend. I hope it is a 429 hemi for what this guy wants for it.
scottk- Posts : 33
Re: 429 Hemi
The Chysler Hemi was also used to power some Air Raid Sirens during the early years of the Cold War. Don Garlits has one in his car museum.
Re: 429 Hemi
The very early cast iron 429 hemi heads, pre aluminum BOSS heads, were used in marine applications. These were the same heads used by Connie Kalitta in the late 60's.
schmitty- Posts : 4538
Re: 429 Hemi
Schmitty I think you are Wrong why in the world would you want to put a Nascar engine on a water well? when the well pump engines only turned 3000 RPM
Re: 429 Hemi
the Coug wrote:Schmitty I think you are Wrong why in the world would you want to put a Nascar engine on a water well? when the well pump engines only turned 3000 RPM
Uh, he said marine application, not well pump.........
Nevs- BBF CONTRIBUTOR
Re: 429 Hemi
Nevs wrote:the Coug wrote:Schmitty I think you are Wrong why in the world would you want to put a Nascar engine on a water well? when the well pump engines only turned 3000 RPM
x2 I'd be willing to bet alot of the program had eyes set on a much broader application base than just NASCAR or a few street performance cars. Thier was alot of research done in the 50's and 60's for the navy as far as alternitve fuels like coal slurry, wierd gasses, ect. I've heard about navy patrol boats using 426 hemis..... On way weird fuels......
Re: 429 Hemi
why would you want to put a well pump engine in a racecar?
Re: 429 Hemi
it's so freaking hard to stay on subject...... Ahhhhhhh... Don't do it.....richter69 wrote:the Coug wrote:Schmitty I think you are Wrong why in the world would you want to put a Nascar engine on a water well? when the well pump engines only turned 3000 RPM
Re: 429 Hemi
Are there any performance parts for the 392's?
I'd like to find an old hemi for this old Model A that my dad has.
jbozzelle- Posts : 3705
Re: 429 Hemi
jbozzelle wrote:Are there any performance parts for the 392's?
Yes
Re: 429 Hemi
So I can pump water in circles.the Coug wrote:Schmitty I think you are Wrong why in the world would you want to put a Nascar engine on a water well? when the well pump engines only turned 3000 RPM
Re: 429 Hemi
schmitty wrote:So I can pump water in circles.the Coug wrote:Schmitty I think you are Wrong why in the world would you want to put a Nascar engine on a water well? when the well pump engines only turned 3000 RPM
Well how did you guys thank he grew his ( Crop Circles )
res0rli9- BBF CONTRIBUTOR
Re: 429 Hemi
I went to see it today, it was a 429 industrial. Thanks for the good info so quickly.
scottk- Posts : 33
Re: 429 Hemi
Scott those are not bad engines I think some may even have a steel crank if I am not mistaken....
Re: 429 Hemi
I have heard that they have the steel crank. In fact I have one in the garage that I havent used it came out of a dump truck. I was definitely disappointed it wasnt a hemi. It was too good to be true. Kinda funny but the guy still insisted it was a hemi and high compression. I started to explain that industrial engines are usually low compression and that a hemi would look quite a bit different but he wasnt having any of it. I am slowly learning to just keep my mouth shut and let folks believe what they want.
scottk- Posts : 33
» Ford's Hemi "The Original Hemi"
» Early 392 hemi crankshaft
» SBF Hemi ...?
» SBF Hemi
» The Hemi-Stang That should of Never been.
» SBF Hemi ...?
» SBF Hemi
