flex plate ring ?
flex plate ring ? Empty flex plate ring ?
Post  nuclearcobra September 10th 2010, 9:41 am
the ring on the back of the flex plate the bolts go through do you have to use it ? the reason i ask is one 460 has it and one didn't. do you guys use them or chuck them ?
nuclearcobra
nuclearcobra
flex plate ring ? Empty Re: flex plate ring ?
Post  Wayne Pearce September 10th 2010, 4:26 pm
I've seen one without the ring, and it had hairline cracks running from bolt hole to bolt hole! When I took it off the engine, the center fell out! It's the only one I recall seeing without the ring, and it's the only one that I've seen broken like that! Cheap insurance?
Wayne (SAWDOFF) Pearce
Wayne Pearce
Post  72mav September 10th 2010, 8:01 pm
Run the ring. It will stabilize your surface area at the mounting holes.
BTW, THANKS for the recipie, I forgot.
Regards.
Al
72mav
72mav
Post  nuclearcobra September 11th 2010, 10:08 am
Kool thanks Al let me know how it turns out.
nuclearcobra
nuclearcobra
Post  jbozzelle September 11th 2010, 11:18 am
Make sure that ditching that ring won't make the bolts stick too far through the crank flange and contact the block. Probably won't happen, but I've heard of it happening before.
