Innovators West Dampers
+20
curleysracecars
bigjohn2007
t-bird racer
56Tbird
stanggt
powerstrokeace
KEVIN S
342g
Scotty 2
4speed
DragBoatRobb
72mav
studly
Bsherry
24 posters
Page 3 of 5
Page 3 of 5 • 1, 2, 3, 4, 5
Re: Innovators West Dampers
KEVIN S wrote:Is anything special needed for the crank trigger setup? Do they offer a crank trigger setup/bracket to match their face or does everyone just use a MSD setup? For the boss snout with crank trigger face plate if it matters. Thank You KS
The MSD bracket can be used.........we have had some brackets made for those that do not already have the MSD stuff.
Lem just a few questions
1) what's needed to work on short or long snouts cranks? (I have both)
2) Is there any up charge in price for the crank trigger unit?
3) do you sell the brackets and the sensor and is there enough hardware for both long and short snout cranks
Ace
Ace
powerstrokeace- Posts : 1496
#209 and shorten the spacer to 2.300"...LONG standard unit.
#210 needs no spacer...plug and play....Boss lenght.
The trigger face option is $89
Hi Lem. Does the trigger face have the magnets in it or do u have to run a magnetic pickup?Lem Evans wrote:#209 and shorten the spacer to 2.300"...LONG standard unit.
Chris
stanggt- Posts : 494
The magnets are emmbedded in the dampner face.....a non-magnetic pickup will be needed.
they're some nice folks to deal with! i sent mine back to them and they changed the face....
Lem, when are these going on sale? Aren't last years models getting a little stale?
738drvr- Posts : 600
Lem ,that one in the pic is a 3 bolt pattern.Do you know what diameter the pattern is?Lem Evans wrote:
Bad to the bone race unit
56Tbird- BBF CONTRIBUTOR
3 bolt is bbc........boss9 snout. The stock lenght snout damper has the 4 bolt bbf pattern.
Lem ,can you see if they'll make a stock length with a 3 bolt pattern?
» ***** innovators west ******
» Innovators West Dampners
» NIB Innovators West balancer ... SOLD !!!
» Thank you B.F. Evans Ford and Innovators West !!!
» New Innovators West Belt Drives
Page 3 of 5
