460 ID Help
460 ID Help Empty 460 ID Help
Post  RidgeRunner September 13th 2010, 6:43 pm
The casting numbers were not clear on the side of the block. But I would like to know how good the heads are along with the year of the block.
D3VE-A2A
The engine block numbers were hard to read. I had 2 of my sons read the numbers to me and this is what we came up with. We are not sure which set is correct.
BWEC635A2 LAST NUMBER COULD BE (9,OR 8
BWEO8(3OR8)5A (9,OR 8
BWEEC9(3,OR 8)5A (9, OR 8
RidgeRunner
RidgeRunner
460 ID Help Empty Re: 460 ID Help
Post  dfree383 September 13th 2010, 7:05 pm
D3 heads are decent and have large chambers. The block should be something like D1VE or D9TE??? Those are the most common ones with D3 heads
Post  res0rli9 September 13th 2010, 7:13 pm
Block #s are on the block where the starter would be. where did you get those #s from, never seen any like that.
Post  RidgeRunner September 13th 2010, 8:14 pm
res0rli9 wrote:Block #s are on the block where the starter would be. where did you get those #s from, never seen any like that.
yes we tried everything we could think of. The problem is the numbers didn't cast very well. Here is a picture after we painted it black.
460 ID Help 100_2226
460 ID Help 100_2225
460 ID Help 100_2224
Last edited by RidgeRunner on September 13th 2010, 8:18 pm; edited 1 time in total
RidgeRunner
RidgeRunner
Post  bbf-falcon September 13th 2010, 8:17 pm
probably D1VE
Post  RidgeRunner September 13th 2010, 8:22 pm
Is there any way to tell what year it is or does it matter?
RidgeRunner
RidgeRunner
Post  droppedf100 September 25th 2010, 2:17 am
Well the D1VE is internally balanced and the D9VE is external. Thats most of the difference. If its external the crank sleeve behind the balancer will have a weight on it kind of like a hatchet blade. It its smooth and round its internal. Your swapping this into the F150?
droppedf100
droppedf100
Post  RidgeRunner September 25th 2010, 8:37 am
droppedf100 wrote:Well the D1VE is internally balanced and the D9VE is external. Thats most of the difference. If its external the crank sleeve behind the balancer will have a weight on it kind of like a hatchet blade. It its smooth and round its internal. Your swapping this into the F150?
Yes I am swapping in the 460 I have. Thanks for the tip I will take a look.
RidgeRunner
RidgeRunner
