Vent fitting on C6, best spot to tap?
Since the destruction of my C6 has meant a complete rebuild I've been reading through the posts by Frank and others. I saw mention of putting a 1/8" pipe thread in the case for a barb fitting to allow a vent; is there any place better than another on the case for this or an area to avoid? Thanks.
77f150- Posts : 220
Re: Vent fitting on C6, best spot to tap?
I just tap in the factory location..
Gregaust- Posts : 624
Thanks, I'll add it to the "to do" list.
77f150- Posts : 220
How is the factory vent fitting held in the case, is it threaded in? Where does the vent fitting go into, does is it just lead into the upper bell housing area?
Gary
Gary
GTmustang- BBF CONTRIBUTOR
It is just a press in fit ,there are serations on the fitting to help hold it there . . Best way is to get some multi-grips , pull the cap off then grab the fitting and it will wriggle out.
Thanks. Am I going to have any problem getting the fitting and hose to fit under my CSR trans shield?
Gary
Gary
» Got to vent
» Hi everybody its been along time but iam needing some help with a build !
» Really feeling bad, have to vent
» Friday night cruise spot.
» Lets play spot the piperack lol
