Electrolytic machining polished chambers
+6
bb429power
DFI429
TeflonDon
jones
10 posters
Electrolytic machining polished chambers Empty Electrolytic machining polished chambers
Post  jones September 27th 2010, 1:54 pm
What are your thoughts of a mirror smooth surface finish combustion chamber? Would it be a better idea to just have the chamber coated? It would seem that even though the chamber is polished it would only last for so long.
http://www.extrudehone.com/ecm.html
jones
Electrolytic machining polished chambers Empty Re: Electrolytic machining polished chambers
Post  TeflonDon September 27th 2010, 4:38 pm
Take my opinion for what it is ............. no hErO here. I would opt for the coating, but I am a little prejudiced. Laughing
TeflonDon
Post  DFI429 September 27th 2010, 4:41 pm
TeflonDon wrote:...I would opt for the coating...
I see what you did there Suspect
DFI429
DFI429
Post  whatbumper September 27th 2010, 5:01 pm
I want the chambers smooth but I don't think "mirror smooth". I would think that it would take away from the efficiency of the chamber itself. I’m sure some of the experts on here will enlighten us all. Very Happy
Post  jones September 27th 2010, 5:40 pm
You would think that a coating would survive detonation a little better.
jones
Post  bb429power September 27th 2010, 6:12 pm
Teflon coating cheers
Here's what it cost's for your parts to be done, look at the animation in the upper left corner.
http://www.gethoned.com/parts.php?get_price=yourparts&show=automotive
bb429power
bb429power
Post  richter69 September 27th 2010, 6:42 pm
my chambers got the Double D rub down............... Wink
Post  138 September 27th 2010, 6:42 pm
does that even work for a street car and the carbon they tend to build up? I would think it wouldn't do sheet, maybe for a racing engine Suspect
138
Post  the Coug September 27th 2010, 7:57 pm
The problem with extrude honing is if your manifold is bad design or head is bad design all it does is make it bigger and still the same bad design just now larger, and smoother.....
JMHO
Post  dfree383 September 27th 2010, 8:09 pm
IMO not worth the cost in a motor like yours, money would be much better spent elsewhere
Post  jones September 27th 2010, 8:17 pm
dfree383 wrote:IMO not worth the cost in a motor like yours, money would be much better spent elsewhere
HAHAHA I wasn't even talking about my engine! (I knew someone would assume that! LOL)
I was reading an artical about pulling heat away from the chamber as fast as possiable to keep it from melting in high temp, turbocharged, endurance race engines. By trying to keep as much heat in the chamber and out the exhaust. Rather than allowing it to soak into the cylinder head.
jones
Post  jones September 27th 2010, 8:29 pm
TeflonDon wrote:Take my opinion for what it is ............. no hErO here. I would opt for the coating, but I am a little prejudiced. Laughing
Do you really coat parts? I always assumed your screen name was just that!
jones
Post  bbf-falcon September 27th 2010, 8:50 pm
Laughing Laughing Embarassed lol! lol!
Post  whatbumper September 27th 2010, 9:46 pm
If your really wanting to keep the cylinders cool just do what I do and run ice water through the engine. I see water temps in the 90's at the end of the run with air intake temps still in the 60's.
Post  jones September 27th 2010, 11:00 pm
whatbumper wrote:If your really wanting to keep the cylinders cool just do what I do and run ice water through the engine. I see water temps in the 90's at the end of the run with air intake temps still in the 60's.
Thats the thing, with an offroad, road race engines ice won't work.
jones
