No longer avaliable - Thanks For Looking
+8
meteor545
Diggindeeper
72mav
Bernie
outlawbird
12 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Well I'm Moving again, and going to give it one more try to sell this stuff, heading Canada this time and I'm hoping to thin my collection down.
If theirs no interest in the stuff this round (everything must be paid for and picked up prior to November 4th, 2010), everything will go back into storage and sit untill I come back if not sold.
Ford Motorsport A460 top end fresh and ready to run.
2.40 TI intakes
New 1.90 Inconel exhausts
New Manley nextek blue strip double springs
New Manley TI retainers and 10 deg locks
heads do have some repairs to a combustion chamber, repair was professional and neat.
touched up and flowed by Charlie Evans
.200 152 100
.300 235 158
.400 310 197
.500 368 235
.600 413 263
.700 437 292
.800 445 314
includes studs, 3/8 guide plates, and a old style ford motorsport single 4 intake.
$2900 + shipping
427 / 428 FE Parts
1EA A casting with extra webbing 428 block .030 over forged pistons, reconed rods with arp bolts, fresh cut crank. Assembly is internaly balanced and assembled. $2500 + Shipping
1EA early 428 block bare fresh .030 over new cam bearings and freeze plugs, wash and put your rotating assesmbly in $850 + shipping
1Set cherry 427 long branch manifolds 63-64 $1100 + Shipping
Various sets of FE Rods small bolt $75 per set + Shipping
Boss 429 Kaase
A460 Block Boss 429 Short Block
A460 Block 4.375 Bore Completely Race Preped
Factory ford forged steel 429 crank .010/.010 coated and lightened
6.800 hbeam rods coated
11.5:1 diamond custom pistons 4.375 bore .17 dyke ring pack
extra set of 10.5:1 diamond custom pistons included
new rings and additional bearings included
Dyno time only all worked performed by Performance Crankshaft out if Detroit
$5000 + Shipping
Complete Kaase Boss 429 top end.
Kaase Boss 429 heads, sn 001 & 002
Manley ss valves, blue stripe Double springs and TI retainers, ported, copper berillium seats filled intake ports.
Kaase 4500 single plane intake, heavily reworked.
WW 1.75 shaft rockers
trend heavy wall push rods
comp cams zbar lifters
comp cams custom roller cam
reproduction boss valvecovers
header flanges
new intake, exhaust and valve cover gaskets
1 set of Kaase spark plug wires and 1 set of Msd wires
1 set of arp head bolts
dyno time only on the parts
$9000 + Shipping
Complete Motor for $15,500 , Includes Danny Bee, Milodon Pan, and MSD Distributor (No Carb)
Boss 429 Boat Headers
Boss 429 Basset Boat headers, painted, dry type, look to be 2" primarys
$350 + Shipping
466" A429 /Aluminum headed Race Engine with ATI C6
Project Cheap Skate - see the self titled thread in the proven build section for specific engine data.
Comes with a new ATI full manual C6 and a new JW 4500 convertor, csr electric water pump, fox or front sump pan (your choice)
complete with 8896 1050 dominator. Only thing you will need is Headers, some bolts and an ignition box.
Some assembly required.....
Going to be moving again and need to get rid of a bunch of stuff I have laying around doing nothing.
Please don't let the title fool you their is nothing "cheap" about what this motor is capible of.... Good fox mustang will go 9's with this motor.
$7500 + Shipping
Franklin Quick Change Rear
Franklin Quick change rear, older unit with steel tubes and detroit locker. Would be great for a street rod or cobra.
disassembled, needs ring and pinion and a couple of bearings
comes with brakes but they are rusty and will need rebuilt or replaced
$500 + Shipping
351 Cleveland Parts
2ea 351c 4 bolt blocks cleaned and mag'd $450 Ea
1ea 351c 2 bolt block cleaned and mag'd $250
1set 351c 4 bolt caps $200
1set OC 4v castings cleaned and mag'd $300
1set CC 4v castings cleaned and mag'd - SOLD
4sets 2v castings cleaned and mag'd $200 for all
351c cranks and rods enquire.
351c spread bore intake $75 cleaned
351c sq bore 4v intake cleaned - SOLD
make offer for the whole lot. All Prices + Shipping
2.40 TI intakes
.200 152 100
.300 235 158
.400 310 197
.500 368 235
.600 413 263
.700 437 292
.800 445 314
$2900 + shipping
427 / 428 FE Parts
Boss 429 Kaase
$5000 + Shipping
header flanges
$9000 + Shipping
$350 + Shipping
$7500 + Shipping
$500 + Shipping
351 Cleveland Parts
Re: No longer avaliable - Thanks For Looking
How would the A460 heads work on a 552cid factory cylinder block build??
Would the chambers be to large, or the heads just plain out over kill?
Looking to build 800+hp na with 10.5 cr.
outlawbird- Posts : 27
The chambers are 78cc on these heads, worst case you might need to notch the cylinder bore at the intake valve. It's been done many times.
In short they will do what your asking.
dfree383 wrote:Well I'm Moving again, Canada this time
Wait, we're full, no better yet, we're closed for the season.
Bernie- Posts : 45
Bernie wrote:dfree383 wrote:Well I'm Moving again, Canada this time
Too Late the Visa is on the way !!! The Yankee is coming to the Great White North
Have fun with the "FROGS".......
72mav- Posts : 1081
72mav wrote:Have fun with the "FROGS".......
Hey the women are hot in Montreal !!!!
careful with the slurs.
Anywhere outside of Montreal they are no longer Frogs, they're Pepsi's (empty from the neck up)
Quebec gormet meal- Poutine, Pepsi, and a Jos-Louis.
good luck with the move Dave, wish i could afford some of your parts.
everyone knows they love us up here in Canada.
bump
Diggindeeper- Posts : 800
im gonna start a "dfree's moving, again" acount at the bank. that way 3 moves from now i'll be able to afford some of his stuff.
meteor545- Posts : 151
meteor545 wrote:im gonna start a "dfree's moving, again" acount at the bank. that way 3 moves from now i'll be able to afford some of his stuff.
I need to start on of those my self, if I had a dollar for everytime I've moved, I be able to afford a mean steak dinner!!!!
Anybody in the Montreal area need some parts delivered, speak-up.... I'll be heading that way in early November and would be happy to help out.
dfree383 wrote:72mav wrote:Have fun with the "FROGS".......
Thats "Frog-Legs"
72mav- Posts : 1081
Got these from his old neigbors me thinks.......
Good luck with the sale Dave, lotsa great parts. Wish I could have come across stuff like this before I built mine, could have saved a bunch of cash.
Bill
billandlori- Posts : 2081
sent a guy to ya for yor Boss stuff.
res0rli9- BBF CONTRIBUTOR
Hey there is a gent who is seriouly looking for Boss 9 stuff! Heads, boat headers etc.....
Just a HEADS UP>>>>
adam
http://www.performanceboats.com/html/forums/showthread.php?t=75229
Just a HEADS UP>>>>
adam
blown86hallet- Posts : 1012
Would the Cleveland 4 bolt main caps fit on a 2 bolt block?
thanksres0rli9 wrote:sent a guy to ya for yor Boss stuff.
I have a fellow Cleveland nut here that might need them. He may want some heads I don't know but I'll ask.
Last edited by Maddmattmustangs on October 4th 2010, 9:06 pm; edited 1 time in total (Reason for editing : To stop further perversion)
Dave, Do the 4v heads have valves?
I have a Cleveland nut... He may want some head
res0rli9 wrote:I have a Cleveland nut... He may want some head
Typo I swear!
Maddmattmustangs wrote:res0rli9 wrote:I have a Cleveland nut... He may want some head
Typo I swear!
Nice..... .
no bareDiggindeeper wrote:Dave, Do the 4v heads have valves?
Page 1 of 2 • 1, 2
» bbf 4340 sizes avaliable
» no longer available
» no longer for sale
» wtb headers and motor mounts
Page 1 of 2
