Just shimmed my distributer and timing doesnt jump all over the place.
Ed501
Bronze gear had slight wear and timing chain had about 3 degrees slack before distr. moved but the problem was .030 too much end play. I thought the cam pulling it down would be good,but i was wrong Boy she revs good again. Thanks
Ed501- Posts : 139
Re: Just shimmed my distributer and timing doesnt jump all over the place.
Now, how are you going to stop the car???
whatbumper- Posts : 3024
So how much are you running now ED?
72mav- Posts : 1081
72mav wrote:So how much are you running now ED?
Ed let us now how doing now
Jim
around 35 total and 16 at idle, alot crisper hope it helps. I had a distr. gear wear from alot of driving-bronze on 351w and it did hurt power up stairs and this is how it acted , i will just cross fingers lol...,ED P.S. stopping helps if i dont watch billboard , i have to hit brakes right after cones
Ed501- Posts : 139
Maybe you caught it soon enough and not hurt anything. Ed you may need to add a chute for all that speed to help them brakes out
Jim
Jim
How did you shim your distributer? How much? I have an issue with my timing moving on me as well. the timing drops by itself after a few passes....not sure how the hell this happens
1Bad91- Posts : 267
Do you move it back to where it was before after it changes itself? Or is the distributor moving? Maybe you have something constantly loosening in the distributor? just trying to help.1Bad91 wrote:How did you shim your distributer? How much? I have an issue with my timing moving on me as well. the timing drops by itself after a few passes....not sure how the hell this happens
You might have fords version of Christene Hit it with a hammer and if its fixed tomorrow your in deep $#!t
bb429power- Posts : 3129
No it's moving on it's on. The initial moves from like 15* to 12* within a few passes
1Bad91- Posts : 267
» Advance Cam or Not ?
» Oliver Rod Price Jump
» you guys ever use a ez-plate they claim it doesnt lean out at all ?
» distributer
» Pinks at Maple Grove/ He GOT 2ND PLACE
» distributer
