F.A.S.T. Wide Band A/F Meter ( dual sensor) NEW PRICE!!
The FAST™ Air/Fuel Meters include several enhanced capabilities, including the built-in data logging capability that plays back recorded information on a lighted, full graphical display screen rather than using a laptop computer. Additional features include outputs for external data loggers, digital gauges, as well as a narrowband simulator function that allows you to feed your engine’s computer a factory signal while using the wide-band sensor for air/fuel measurement.
This unit was only used twice. The plastic is still on the screen. As new condition. FAST Pt# 170402.
$400 SHIPPED ANYWHERE IN THE CONTINENTAL U.S.
Thanks, David
Westlake, La.
337-3842-6695
Thanks, David
Westlake, La.
337-3842-6695
Last edited by harleydave on November 10th 2010, 8:02 pm; edited 2 times in total (Reason for editing : correction)
harleydave- Posts : 13
Re: F.A.S.T. Wide Band A/F Meter ( dual sensor) NEW PRICE!!
I wonder what the differece is between the gas set up and the E85 set up. Looking to go E85 but I have 3 cars to set up and want one system to move from one to the other after things get tuned?
I'll call F.A.S.T
Ace
I'll call F.A.S.T
Ace
powerstrokeace- Posts : 1496
Part number is really 170402. Also haven't been able to get through there dam tech center to find out what the difference is between the GAS and E85
Ace
Ace
Correction
Sorry, yes it is 170402. I edited it above. Thanks
ive got the same one and i love mine works awsome
will it work with leaded fuel or just unleaded
reeseracing23- Posts : 70
I used it with race gas, but only for a limited time while tuning. i did not leave the sensors in the exhaust all the time. I have seen differing opinions on how long the sensors will last with leaded fuel. Some have gotten years of service, some not. There is a forum at www.fuelairspark.com that may be able to answer that better. Thanks David
ive had mine for 3 years with c-16 to pump gas still works just fine -as long as you let the sensors heat up ,you will be good
» innovative wide band meter
» comp roller lifter , innovative lm1 wide band and more
» Fast methanol/e-85/e98 a/f meter with rpm module and new 02 sensor
» Wide power band street bbf
» Daytona Sensors Wide Band kits
