ISKY Easy Roll Lifters
ISKY Easy Roll Lifters Empty ISKY Easy Roll Lifters
Post  CDMBill October 27th 2010, 1:04 am
I'm due for a new set of lifters, two seasons on my current set of of Crane Ultra-Pros (remember them?) and I begin to worry. Since I have to change brands I thought the Isky Easy Roll has a good story? My application is an A460 head EFI 581" pump gas deal with an .800 lift solid roller, 300#+ at the seat (see proven builds) that sees lots of street miles and maybe 70-80 passes a year.
Has anyone run these lifters enough to have a sense of their durability? I know the Red Zone lifters have a good reputation but the new deal seems appealing to me, call me crazy.
CDMBill
ISKY Easy Roll Lifters Empty Re: ISKY Easy Roll Lifters
Post  bruno October 27th 2010, 10:34 am
COPY AND PASTE
Background: Plain vs. Needles
For decades, engineers have realized that nothing carries more load than a plain bearing. The problem has always been in delivering enough oil to cool and lubricate its inner raceway. Needle-roller bearings have gained a foothold in applications such as roller lifters because they have traditionally faired better under sparse (less than optimum) lubrication conditions, in reducing friction. Recent advances in materials technology have changed this concept forever and Isky is proud to be leading the charge for the plain bearing revolution!
Cutting Edge Material & Oil Delivery Science
A revolutionary new ultra low friction material is the key to the new EZ Roll™ bearing’s success. The proprietary bearing raceway carries tremendous loads and has a drag coefficient which approaches that of ceramic, without any of the poor impact resistance (shock load) properties of these materials. Coupled with Isky’s precisely engineered exclusive multi-point oil delivery system, the EZ Roll™ bearing is absolutely the best engineered, best performing roller lifter bearing on the market today!
Problems with Needles in Heavy Load Applications
Extensive Spintron® testing in the Isky research lab has confirmed that rather than being continuous and orderly, needle-roller motion in the typical roller lifter bearing is anything but! To the contrary, needle roller motion is actually subject to a harmonic wave-like action which oscillates between the ‘bunching-up’ and spreading apart of the needles, due primarily to the deflection or bending of the outer bearing race. This deflection (because of extremely heavy valve spring loads and tremendous dynamic forces) is aided by the relatively poor ratio of load distribution to surface area in contact of the needle roller bearings. This is why even the premium prices $2,000+ lifter sets occasionally fail! The problem is not one of material, but in the design of needle roller bearings and their small footprint of contact. In contrast, the EZ Roll™ bearing boasts a solid 350% higher load rating because of the elimination of the needles! Their ultra low friction raceway material rolls so easy under heavy load (drag and pro-street) applications, it’s no wonder Jim Oddy & other racers report they seem to practically run forever!
Record Setting Performance
Jim Oddy’s recent record setting performance in his 10,000 RPM Pro-Mod (Doorslammer) was set running over 450 lbs seat and 1300 lbs open valve spring pressure. He reported his Isky EZ Roll™ bearing equipped Red Zone™ roller lifters performed flawlessly.
Tremendous Value
Because Isky’s new EZ Roll™ bearing option (for Red Zone™ roller lifters) delivers such dramatic improvements in roller lifter performance, they are of course priced as an upgrade/premium. In many cases however, such as with the more accurately machined after-market engine blocks, you eliminate the need to ‘over-bore’ the lifter holes, so you avoid the costs involved to do so and the increased weight associated with ‘oversized’ lifters. This and their dramatic increase in longevity make the EZ Roll™ bearing option a tremendous value!
http://WWW.CKRME.COM
Post  Lem Evans October 27th 2010, 11:19 am
Bill, there was some discussion about these lifters on the speed talk site a while back.......you may want to do a search over there.
Post  bruno October 27th 2010, 11:29 am
http://speedtalk.com/forum/viewtopic.php?f=1&t=23327&hilit=isky
Post  CDMBill October 27th 2010, 11:44 am
Thanks guys, Lem do you stock these, and do they come in .904 or .937 and are the rollers wider or larger as they are on some other brands?
CDMBill
Post  Lem Evans October 27th 2010, 12:20 pm
No sir i'm not a Isky dealer. The other brands I'm aware of get a bigger dia. wheel when you go to the .904" stuff......you'd have to contact isky to see what they do.
