Questions on a 4.3 crank...
Found an eagle 4.3 steel crank for sell. I can get it for cheap. How do I tell if its really steel and is a 4.3 stroke? Also what rods do I need 6.7 or 6.8? Thanks
cobra460jet- Posts : 12
Re: Questions on a 4.3 crank...
6.7 or 6.8 will work...just get the correct piston for the rod lenght.
cobra460jet wrote:Found an eagle 4.3 steel crank for sell. I can get it for cheap. How do I tell if its really steel and is a 4.3 stroke? Also what rods do I need 6.7 or 6.8? Thanks
Scat cranks are stamped on the first counterweight, i'd assume Eagle would be marked somehow .
Gregaust- Posts : 626
Eagle cranks have a part number etched in on the front of the front counterweight and this will tell you what part you have in hand.
DaveMcLain- Posts : 399
Thanks guys Ill look at it tonight.
» differences in 68-69 crank pulley to 70 and up crank pulley for Lincoln with crank PS
» WTT hawks/RPM 4.5 stroke cast crank for 4.150/514 crank
» New combo Idea for my 73 mustang....
» Looking to trade a BBF MSD crank trigger for a SBF crank trigger
