Header Fabrication from BT to A-460 TFS
DanH
smackjack
Guys,
I need to make some new headers for my BT with Chevy Ext. ports but later might change combo to a-460 tfs
heads...just wondering if head dimensions are close in size-width- height etc. for frame clearance...I've bee down this road before when I changed from Ford Iron CJ to BT...BIG Difference!!! in size of head and port location etc.
Has anyone done this Combo Change???
smackjack- Posts : 16
Re: Header Fabrication from BT to A-460 TFS
Only with a drag boat ... the headers fit the same but, there was not shock towers or a floor pan to worry about.
What's the front suspension of your truck consist of? What is in the way now that you have to work around?
jbozzelle- Posts : 3705
can't seeing them as a direct fit in a car .tube or with towers . BT's have extended port and angles down , A head set back along wih angle
DanH- Posts : 1081
Alot of room between frame rails and motor, but I do have alot of motor set-back...like all Trucks and I'm running a Mustang II front end.jbozzelle wrote:What's the front suspension of your truck consist of? What is in the way now that you have to work around?
Both the B.T. "B" heads with the Chevy bolt pattern and the new style TFS A-460 heads with the Chevy bolt pattern are on 4.840" Chevy bore centerline at the exhaust flange. In other words a one piece Chevy header gasket will work with both sets of heads! Therefore you will have no issues in regards to front to rear measurements of the primary pipes.
There is a difference in the angle of the exhaust flange surface between the two heads. Also a difference in the height above the deck surface of the exhaust ports between the two heads. The only issue I see is that by the time this all plays out at the collector,,,,,,one collector may be hitting the floorboard,,,,, whereas the other heads with the same headers, the collector may clear the floorboard just fine.
Hope this helps,
Charlie
Hope this helps,
Charlie
c.evans- BBF VENDOR SPONSOR
c.evans wrote:Both the B.T. "B" heads with the Chevy bolt pattern and the new style TFS A-460 heads with the Chevy bolt pattern are on 4.840" Chevy bore centerline at the exhaust flange. In other words a one piece Chevy header gasket will work with both sets of heads! Therefore you will have no issues in regards to front to rear measurements of the primary pipes.
Hope this helps,
Thanks Charlie...that's what I needed to know, any idea on how much higher port is raised on a TFS compared
to a BT so I can allow for clearance? I have alot space due to its a Truck
Charlie
smackjack wrote:c.evans wrote:Both the B.T. "B" heads with the Chevy bolt pattern and the new style TFS A-460 heads with the Chevy bolt pattern are on 4.840" Chevy bore centerline at the exhaust flange. In other words a one piece Chevy header gasket will work with both sets of heads! Therefore you will have no issues in regards to front to rear measurements of the primary pipes.
Hope this helps,
Charlie
Hey Jack good to see you on here Chris modified Butch's Blue Thunder headers to work with his A-460 Heads.I would give him a call and ask him how much work was involved.
Later Mark.
Mark Miller- Posts : 1959
Yea Mark, I already talked to him...I'll need to make new Headers, mine are too beat up...and patched up.
if you need any material or supplies please keep us in mind. Here is a link to our website : wwwfabshopheaders.com
Tim
Tim
fastracecars- Posts : 25
I got the stuff to build my headers from Tim and the bends, flanges, and collectors were some real top notch stuff. He was real nice about giving me a bunch of advice on how to fab them up too.
schmitty- Posts : 4538
smackjack wrote:Yea Mark, I already talked to him...I'll need to make new Headers, mine are too beat up...and patched up.
Gottcha that makes sense i thought you just wanted to modify what you have.
Later Mark.
» Header Fabrication
» Billet Fabrication Oil Pan and Kaase Pump. SOLD
» Billet fabrication Jeff Johnston 2 peice aluminum oil pan w/ Titan pump & pick-up
» header
» Header Help.
» header
» Header Help.
