Starter Suggestions?
+11
gdyck64
BRONCOBILLY7.5
kjett
gryphon68
Touch N Go
56Tbird
Fast Fox
15 posters
Starter Suggestions? Empty Starter Suggestions?
Post  Fast Fox August 27th 2009, 7:56 pm
Well i'm about to get my fox lined out but keep running into snags. My csr starter took a poop on me this evening. Pulled it and bench tested all it does is kick out but will not turn same thing it did on car and draws amazing amounts of current and gets hot quickly Mad So what do you guys suggest 557 with 13:1 compression I am a budget minded guy but don't want to go too cheap and buy junk!
Fast Fox
Fast Fox
Starter Suggestions? Empty Re: Starter Suggestions?
Post  Lem Evans August 27th 2009, 8:03 pm
1995ish starter for the F250/F350 w/460".
Post  dfree383 August 27th 2009, 8:04 pm
90's ford truck mini gear reduction starter is what I have on my 528" motor. Works great.
Post  56Tbird August 27th 2009, 8:05 pm
Make sure you get one for a automatic tranny Wink
56Tbird
56Tbird
Post  schmitty August 27th 2009, 8:23 pm
56Tbird wrote:Make sure you get one for a automatic tranny Wink
Definately specify auto trans. There are IIRC 3 different applications and the one for a manual will not work.
Post  Fast Fox August 27th 2009, 8:28 pm
dfree383 wrote:90's ford truck mini gear reduction starter is what I have on my 528" motor. Works great.
Which mini gear starter do you have a factory ford? If so give me exact specification PLEASE!!
Fast Fox
Fast Fox
Post  Touch N Go August 27th 2009, 10:03 pm
me to, 93' F350-automatic, 460, turned my 15.5:1 over for 2 seasons of mud racing with no problems, also under $150 Canadian
Steve
Touch N Go
Touch N Go
Post  Fast Fox August 27th 2009, 10:14 pm
I found and just purchased one! Thanks for all of you guys help I just saved a ton of money over that pos 330 dollar csr.
Fast Fox
Fast Fox
Post  gryphon68 November 24th 2009, 1:58 pm
Part Number appears to be F2TU-11131-BA. Can someone please confirm.
"BA" Suffix is important! The "CA" is for Manual Transmissions.
gryphon68
Post  kjett November 24th 2009, 11:46 pm
I got mine from fleabay from a place called dbelectrical. Paid $50, which was much cheaper than geting it from the local Napa. Here's a link to the auction if you want it:
http://cgi.ebay.com/ebaymotors/NEW-Ford-Mini-Starter-Truck-Van-Mercury-460-engine-3226_W0QQcmdZViewItemQQhashZitem5ad5209493QQitemZ390122738835QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
kjett
kjett
Post  BRONCOBILLY7.5 November 25th 2009, 4:28 pm
Ford part # F2TZ-11002-BRM Motorcraft # SA-794-RM. MSRP 114.70 exchange. I've used this stater on my 466 for the last 5 years w/ no problem.....knock on wood.
BRONCOBILLY7.5
BRONCOBILLY7.5
Post  jasonf November 25th 2009, 6:35 pm
kjett wrote:I got mine from fleabay from a place called dbelectrical. Paid $50, which was much cheaper than geting it from the local Napa. Here's a link to the auction if you want it:
I also got my small block starter from DB. They have great service I found.
Starter Suggestions? Empty Starter nose length
Post  gdyck64 January 9th 2010, 9:02 pm
Is there a difference in nose length between the auto and manual sarters? I have a manual transmission model and it does not extend far enough or engage deep enough in the flywheel, it just catches the tips of the teeth. The depth from the starter attachment face to the leading edge of the flywheel is about .850". I have a Lakewood scattershield, any help would be appreciated.
gdyck64
Post  72puller January 10th 2010, 12:27 am
I don't know if there is any difference between the manual and auto starters. But I do know the late model starters don't work with a lakewood bellhousing. The drive gear is offset away from the flywheel to far. The early model starters work good with a Lakewood.
Dennis
72puller
72puller
Post  TommyK January 10th 2010, 3:10 pm
X3 on DB Electrical
TommyK
Starter Suggestions? Empty It runs!!!!
Post  gdyck64 January 10th 2010, 10:25 pm
I put an old style starter on and it sounds great and I was able to start the engine for the first time. It is a 557 SCJ in an FFR roadster, sounds great. Thanks for the help.
gdyck64
Post  nitro521 January 10th 2010, 11:14 pm
x4 on the db's I have had good luck with mine on a hard turning 545 with 13.5. Cheap enough to buy a spare to have around.
nitro521
Post  FOXBODY101 January 14th 2010, 7:47 pm
what starter should use with a power glide....
FOXBODY101
FOXBODY101
