87 Mustang GT questions
87 Mustang GT questions Empty 87 Mustang GT questions
Post  Budman August 27th 2009, 9:11 pm
I would like to work more on my BBF Pinto more, but I need to fix the wifes car. Her 5.0 has a problem. I had to adjust the timing just to get it running. Even at 80K miles it was smoking and a chugging.
* The check engine light never came on
* It blew out the PCV valve
* Checked the distributor gear/pin, fine.
* Timing gear chain still matched up good
* I ran a compression test on only a few(3) cylinders, and it checked out OK.
* After a bit of time sitting the oil pan had anti-freeze in it ( quart or two)
Would just a leaking head gasket do this much?
Any ideas would help greatly
Thanks in advance
Budman
Budman
Budman
87 Mustang GT questions Empty Re: 87 Mustang GT questions
Post  69F100 August 27th 2009, 10:47 pm
that what it sounds like to me but you need to pull compression check on all 8 to see if it is a head gaskit if all 8 are ok i would say it would be intake or cracked head just my 2 cents
Jim
Post  Budman August 28th 2009, 12:34 pm
Thanks for the reply. Sadly I took it all apart, so now I guess I will just get everything crack checked. I was also curious why I had to adjust the timing just to get it to run (barely)? Enough adjustment needed that I had to lift the distributor and move it a tooth on the gear. Good thing is that she wants to add a few go-fast goodies.
Budman
Budman
Budman
Post  83-88T-Bird Guy August 28th 2009, 1:13 pm
We bought our 84 T-Bird 5.0 from a donation place and all that was wrong with it was 3 quarts of coolant in the oil pan. Turned out to be a faulty head gasket. I replaced BOTH head gaskets to be safe and the engine has been fine since.
You might get lucky and all you have is a faulty gasket.
83-88T-Bird Guy
83-88T-Bird Guy
Post  Northwest outlaw August 28th 2009, 1:14 pm
thats funny that it did any thing the timing is runned by the ecu.
Northwest outlaw
Northwest outlaw
Post  bbfstang August 28th 2009, 6:54 pm
Bad head gasket gets my vote to...
bbfstang
