Anybody using the Moroso 20625 drag race pan with a stroker crank?
Moodyblues
'65 T-BOLT
Anybody using the Moroso 20625 drag race pan with a stroker crank? Empty Anybody using the Moroso 20625 drag race pan with a stroker crank?
Post  jbozzelle November 4th 2010, 5:38 pm
I'm curious if the scraper and windage tray need to be trimmed to clear the crank. I'm running a 4.14 crank now but will surely stick a 4.5 in there at some point.
http://www.jegs.com/i/Moroso/710/20625/10002/-1
Anybody using the Moroso 20625 drag race pan with a stroker crank? Empty Re: Anybody using the Moroso 20625 drag race pan with a stroker crank?
Post  richter69 November 4th 2010, 5:42 pm
seems we had to bend it down with the 466 deal years back.
Post  '65 T-BOLT November 4th 2010, 5:44 pm
thats the pan I have on my 521...4.3 stroke...clears everything....I do not remember having to clearance anything...
'65 T-BOLT
'65 T-BOLT
Post  richter69 November 4th 2010, 6:19 pm
scraper is what hit on ours.
Post  Moodyblues November 4th 2010, 7:27 pm
Guess my pan is different cause I dont have the cutout in mine..........its full race for tube chassis.........no problems
Moodyblues
Moodyblues
http://www.russhoodinsurance.com
Post  jbozzelle November 4th 2010, 7:28 pm
Thanks. I sold the street/strip pan and am looking to get this one.
Post  Lem Evans November 4th 2010, 7:42 pm
jbozzelle wrote:I'm curious if the scraper and windage tray need to be trimmed to clear the crank. I'm running a 4.14 crank now but will surely stick a 4.5 in there at some point.
It'll work with the 4.5"
Post  BOSS 429 November 4th 2010, 8:53 pm
i have a few 4.150s out there with this pan,4.300s, and 1 4.750 arm same pan, the 4.750 had to do work around pan bolts
Post  IDT-572 November 4th 2010, 11:42 pm
It cleared fine on my 4.5 inch crank, but the scraper touched the rod bolts on the 528 I built for Mike Jowarski. It had the 2.5 inch Ford crank pin, It was no problem to make it clear.
Post  bbf-falcon November 6th 2010, 9:08 pm
Same pan I have,mine cleared fine. Kaase pump didn't though,had to open up the front sump abit.
Post  jbozzelle November 7th 2010, 2:12 pm
bbf-falcon wrote:Same pan I have,mine cleared fine. Kaase pump didn't though,had to open up the front sump abit.
Thanks Rick. Forgot about the Kaase pump. Guess mine won't fit either. You have a full chassis pan or the Fox body swap pan?
How did you open yours up? Just make a little box to go around the pump housing?
Post  IDT-572 November 7th 2010, 10:58 pm
Mine was a fox pan and the Kasse pump fit it.
Post  jbozzelle November 7th 2010, 11:27 pm
I'll have to measure the pump to make sure it'll fit.
