Wanting to step up cam but would need to go to 111-112 LSA from 110LSA IS that a bad Idea?
DanH
Ed501
Only have .080 P/c clearance and want to go to a cam around 273@.05 730-740 lift from a XR304R with 268-682 lift 110LSA installed at 108 IC. I know there differant ways to gain clearances. Just wondered on a 501 cube motor how the wider lsa would work between 5000 and 7000 rpms. I beleive i might loose some mid range torque but 5000 is barely midrange? Thanks for anyones experiance, When the time comes i will probably order a custom cam from LEM or someone on here.
Ed501- Posts : 139
Re: Wanting to step up cam but would need to go to 111-112 LSA from 110LSA IS that a bad Idea?
what about retarding the cam 2-4* to gain more clearance ???
.080" cl on both valves , I'd run it . not a hyd cam , your lifters won't pump up
DanH- Posts : 1081
Why only .080 clearance ? What is your set up.
Retarding would gain clearance on one valve and lose it on the other.
I would just get an Inski tool and cut the notches deeper with the pistons in the engine. That way your able to run what ever cam you need to with no worries. JMHO
IDT-572 wrote:Why only .080 clearance ? What is your set up.
X2
i'd call Lem and see what he thinks.with a wider lsa you may not loose any pvc.i went from 108 to a 112 and had more room even with much more lift and duration.a lot depends on the profile,hell i dont know! call Lem!
Motor would need to come apart??
I would like to hear from someone that has done it with pistons not taken out to clean . I guess a surgeon could do it using tape and alot of it and maybe some wheel greese around edge of pistons to keep any thing out that got pass. I dont mind pulling engine since i got the tranny out anyway. Sounds kinda iffy to me
Ed501- Posts : 139
Do a Search . Theirs a post on here showing Kaase doing it on a short block.
res0rli9- BBF CONTRIBUTOR
I have done it with a shop vac and tape.
notcher
Did you use a isky tool or a Lindy tool? Did you do it by hand,wrench or drill? I getting braver lol
Ed501- Posts : 139
I have a cutter from Edge tool.
Ed501 wrote:Did you use a isky tool or a Lindy tool? Did you do it by hand,wrench or drill? I getting braver lol
Isky tool and a drill. I actually have done one on a diesel that had no valve cant. I wouldn't suggest doing that. The cutters are made to only cut across less than half the face. They don't plung cut for crap.
Check out the link below to a thread on Ford Muscle.
As Blake stated above, don't be afraid of tape and a shop vac.
http://www.fordmuscleforums.com/engine-articles/483580-notching-pistons-car.html
83-88T-Bird Guy- Posts : 1003
» Header diameter and step vs non step
» Wanting to find ...
» For those of you wanting pic of new ride
» Wanting a boat like Bruno's
» Wanting to get my feet wet with Big Blocks Now!
