I need a set of 4.10 High pinion Dana 60 gears to replace 3.55's
Anyone got anything the'd like to part with or trade for the 355's? I'm swapping 4.10's in the rear of my truck and need some gears for the front.
Thanks,
Greg
Thanks,
Greg
Greg_P- Posts : 1009
Re: I need a set of 4.10 High pinion Dana 60 gears to replace 3.55's
Aww man, I could really use a set of these front 4.10's. The 3.55's ain't cutting it while pulling the boat.
Greg
Greg
I bought a new set a couple years back from Yukon, and they weren't that bad like a couple hundred bucks or so. Have you priced a new set?
schmitty- Posts : 4538
Here is a set from Randy's for less than a couple hundred.
http://www.ringpinion.com/ProductDetails.aspx?ProdID=3706
Greg,your doing the right thing,I made that same switch, and it is like towing w/completely different truck
Thanks for the info, guys..... This front axle originally had 4.10's in it but I swapped in 3.54's to match my rear axle.
Then I threw the 4.10 gears away like a jackass.
The 3.55's are definitely NOT the hot ticket for towing anything....lol......
Greg
Greg
I may have a set in a couple days. I have a costumer bringing me a d60 for a gear swap not sure what is in it yet though. It will be 3.54 or 4.10. it a 79 front 60
I am also a full yukon dealer. www.lonestaraxle.com
Cool, I'd be interested in the gears if they're in decent shape.
Just let me know.....
Thanks!
Greg
Thanks!
Greg
» Dana 60 high pinion gear
» anyone run a rack and pinion steering on a dana 44 straight axle???
» Dana 60 ring and pinion SOLD
» Dana 44 4.11 gears
» DANA 60 3.73 used gears
