what studs/bolts are ya'll using on splayed 4bolt caps?
I was gonna order some arp 2bolt main studs and then getting some grade 8 bolts for the outer. Any other recommendations?
Thanks, Casey.
Thanks, Casey.
8liter- Posts : 202
Re: what studs/bolts are ya'll using on splayed 4bolt caps?
that should work fine, but measure the length of the studs before buying them, some caps require a slight different lenght.
dfree383 wrote:that should work fine, but measure the length of the studs before buying them, some caps require a slight different lenght.
So do I need a custom set of bolts? Or will a off the shelf's work?
8liter- Posts : 202
I ran my 15:1 557 with aftermarket caps with grade 10 SHCS's Bought at our local bolt and screw house. Inners and outers.
8liter wrote:dfree383 wrote:that should work fine, but measure the length of the studs before buying them, some caps require a slight different lenght.
Need to measure first, depends on what caps you use.
» How much does it cost to get 4bolt caps get put on?(roughly) and what can my 77 460 block with center 4bolt caps block handle?
» Wanted: splayed main caps
» 4bolt main caps
» torque specs for svo block splayed main cap bolts
» I'm looking for splayed 4-bolt main caps...
» 4bolt main caps
