Going to test tonight
westsideford
Old blue Racin Team
stangr8cr
Greg_P
We'll see what the +1.5" of front suspension travel does for the launch. Also gonna play around with nitrous activation rpm and see if we can find a sweet spot.
Greg_P- Posts : 1009
Re: Going to test tonight
Good luck Greg!! hope you had your bowl of soup!!
Wink Wink!!
Boo Boo
Wink Wink!!
Boo Boo
stangr8cr- BBF CONTRIBUTOR
Good luck man
Old blue Racin Team- Posts : 1579
good luck and have some fun and be safe
Good Luck Greg.. Hope you do good!
westsideford- Posts : 398
good luck Greg ...be safe
Good luck Greg.
jasonf- BBF CONTRIBUTOR
Best of luck, Greg. We will need numbers...
Nevs- BBF CONTRIBUTOR
Nothing broke, nobody got hurt..... It was ladies night (!) at the track and they had a live band playing, too!
Anyway, with poor track prep at our local 1/8 mile we did our best 60 foot we've ever done there.... a 1.53.... not anything to write home about, but the front suspension mods seemed to buy enough time to let the rear suspension work.
Changes we made to the shock settings actually made a real difference in the 60 foot times for the first time, too.
So, the changes we made netted a positive effect, adjustments made had the desired results, and our 60 foot times are back where they should be.
A good night.
Hope everyone else did well tonight as well!
Greg
A good night.
Greg
Last pass of the night......
A little squirrely, but it was the best 60' of the night. I got caught up in "burnout-showoff mode" and remembered Wes's busted rod in the burnout box, so I let off.....at 7200 rpm!
Looks purty good man
Nice pass Greg, that wasn't no showoff burnout. Just lettin the street car know who's boss!!
BooBoo
BooBoo
greg, what did you do do get that extra travel in the front? i could use some tips as i redo the front suspension
duff429- Posts : 202
Well, it was a big pain in the buttocks to get that extra travel.
First, I notched the frame rail under the upper control arm to allow the arm to pivot down further. The welded the frame back together.
Then I realized the upper ball joint was in a bind at full compression, so I made a spacer similar to a negative wedge kit to go under the upper ball joint and corrected that bind.
After that I noticed that the ball joint was now in a bind at full extension. So, I had to disassemble the joint and grind the housing to allow a little more articulation of the joint.
Once all that was done, I discovered the shock was too short. After a bunch of searching I found that a '67 Nova shock would work, and installed those.
Then there was little stuff like rerouting the brake lines and extending the upper suspension bumpers, etc.....
Greg
Greg
» Test & Tune Tonight
» tnt tonight!
» UFC Tonight 11/21/09
» Well, I went and done it tonight...........
» chat tonight?
» tnt tonight!
» chat tonight?
